pilot jet stuck !!!!
- triggerbilly
30 Jun 2008 20:29
OK
it's been suggested that my pilot jets may be plugged/blocked
(thanks wiredgeorge)
It could well be this
when i was cleaning them recently i couldn't remove them and feared damaging them i didn't wanna strip them.....
any advice ????
any advice ????
1982 kz750-e3
1983 cb1000c
plano. TX
1983 cb1000c
plano. TX
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
Re: pilot jet stuck !!!!
01 Jul 2008 04:54
The advice I was given from an old KZ mechanic was "find a screwdriver that JUST fits into the hole so that it engages the maximum amount of slot on the jet. If necessary, get a wider bladed driver and grind it down to fit".
I followed his advice - actually had a screwdriver that "just" fit into the hole and I had no problem. Do be careful, and if you cannot get it free, take it to a machine shop and let them get it out!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
1978 KZ650
2000 ZG1000
- mtkawboy
01 Jul 2008 08:59
Soak it good with PB Blaster then do as said above. You wont strip them but you might break the brass screwdriver slot off with the wrong screw driver. Then you are hosed. Id replace them, dont even try to clean them. Youre milage may vary
