carb swap
- gkn3529
30 Jun 2008 17:50 #223150
by gkn3529
carb swap was created by gkn3529
Can anyone tell me if 82 KZ1100 carbs will fit on a 80 KZ1000? I am thinking about buying the KZ1100 carbs, but I am not sure if they will mount up without changing the intake boots.
- mtkawboy
- Thank you received: 16
30 Jun 2008 17:59 #223155
by mtkawboy
Replied by mtkawboy on topic carb swap
They will fit with the bigger boots for the Cv carbs
- gkn3529
30 Jun 2008 18:10 #223158
by gkn3529
Replied by gkn3529 on topic carb swap
Will I be able to keep the factory airbox with them? Thanks.
- wiredgeorge
01 Jul 2008 06:50 #223274
by wiredgeorge
Replied by wiredgeorge on topic carb swap
No... the outside diameter of the later BS34s is 54mm and the outside diameter of the OEM VM series carbs is 43mm. Not only will you have to swap carb holders but you will need to use a different throttle cable.
- mtkawboy
01 Jul 2008 08:55 #223294
by mtkawboy
Better ask George how to jet it too, youll never figure it out with pods. CV's dont like pods for me.
- gkn3529
01 Jul 2008 17:43 #223366
by gkn3529
Thanks for the info. I think I will stay away from the 1100 carbs. I found a set of 81 KZ1000 CV carbs that should be a better fit. I am trying to get away from the accelerator pump carbs that are on my KZ1000E2. I hate those things. I'm not trying to make it fast, just smoother and more efficient.
- mtkawboy
01 Jul 2008 19:19 #223394
by mtkawboy
Still pretty close to the same thing carb wise. I dont know if that airbox will fit your frame or not
- wiredgeorge
02 Jul 2008 05:45 #223464
by wiredgeorge
This is correct... same exact issues as the carburetors are physically identical. I know what you mean about the accelerator pump. I personally am not a fan. About 2/3 of the pump assemblies that come through our shop are NOT working... when the pump doesn't work, the bike will run but without that shot of gas when the throttle is twisted, they are not smooth and the jetting is no longer up to the task, even with a stock airbox. We are fully able to make the pumps work and we rebuild/verify each pump assembly but they are an addition complication. We remove the pump assemblies and pump bowls from several dozen sets a year and convert them to non-pump for this reason.
