vaciuum problem ?????
- triggerbilly
29 Jun 2008 20:02 #222951
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
vaciuum problem ????? was created by triggerbilly
just started my kz750-e3, and........
pretty much the same problem as last week!!!
well at least my carbs are cleaner now
as i just cleaned them again !!
I guess it started a little easier but still pretty much the same prob.
it runs with a rag jammed in the top of the air filter top ????
pull it out slightly while the engine is running and the bike begins to die,
stuff it back in and it comes back to life.
after 5 mins idle around 2000rpm (won't rev without cutting out)
cylinder 1 - hot
cylinder 2 - warm
cylinder 3 - RED HOT !!
cylinder 4 - hot
tried the wd40 intake tip and no change in rpm's
It feels like a vacuum problem (right or wrong ?)
but can't think of anything else to try.
hope my findings help someone to HELP ME !!!!!!
thanks
cylinder 1 - hot
cylinder 2 - warm
cylinder 4 - hot
thanks
1982 kz750-e3
1983 cb1000c
plano. TX
- TeK9iNe
- What did you do!?!
- Thank you received: 28
29 Jun 2008 20:43 - 29 Jun 2008 20:45 #222964
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic vaciuum problem ?????
Sounds like your running super lean. If the bike has a richener circuit, open it full and observe any change.
Check the condition of your plugs, and compare them to a good plug chart. Here's a real good one: www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html This will tell you alot about whats going on in each cylinder.
I am saying this with the assumption that all your valve clearances are correct, and compression is good.
Good Luck.
Dont forget to check for posible vacuum leaks everywhere in the carburetion path...
Good Luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 29 Jun 2008 20:45 by TeK9iNe.
- ronjones
- Thank you received: 4
30 Jun 2008 05:20 #222998
by ronjones
Replied by ronjones on topic vaciuum problem ?????
I saw your other post on this subject, a while back, and figured one of the other guys would ask this. If I understand you correctly, you are using a stock airbox w/filter. Here's where I'm a little fuzzy on whats going on. Are you stuffing the rag on top of the airbox because you don't have an air box lid, or are you stuffing the rag in the box and then closing it up w/the lid? I could see, if you were using the rag as a lid, you could be just getting too much air going through the airbox, especially since the box lid is required to keep a good seal on the filter. It would seem using a rag for an airbox lid would not be much more sealed than an open airbox.
- wiredgeorge
30 Jun 2008 07:42 #223030
by wiredgeorge
Replied by wiredgeorge on topic vaciuum problem ?????
The pilot circuit is plugged up or the pilot jets are obstructed. Are these CV34 carburetors? I suggest you FIRST give a bit of back ground. Have you eliminated other tuning issues by adjusting your valves? How is compression? It may be that you have an ignition issue as well as a carburetor issue. Sounds like cylinder #2 isn't firing at all. You might want to spray some water via a pump bottle (orange cleaner also works well or Windex) on the pipes. If the cylinder is firing, the water will vaporize. If the cylinder is non-firing, the water will spit on the pipe and roll off. Do this and get back to me. ID the carbs... It is a bit tough to clean the pilot circuit on the CV34s... harder than on BS34s.
- triggerbilly
30 Jun 2008 11:04 - 30 Jun 2008 12:15 #223072
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Replied by triggerbilly on topic vaciuum problem ?????
the lid is on the airbox, I'm just stuffing the rag into the hole in the lid of the airbox acting like a choke i guess. all the components are there for the airbox it just ain't workin' !!
I haven't checked the valves because this really all started straight after i took the air filter out and replaced it.
before that the bike ran ok (not perfect, but alot better than it is right now)
UPDATE !!!!!
just went out to try again and put the petcock to prime !!
and it started alot better and stayed running.
the idle was a little irratic though.
i did the squirt test on the exhausts like you suggested george. 1,3,4 it evapourated to nothing and on 2 it just trickled down
also it is now backfiring alot
still progess (kind of !!!!)
UPDATE !!!!!
1982 kz750-e3
1983 cb1000c
plano. TX
Last edit: 30 Jun 2008 12:15 by triggerbilly.
- wiredgeorge
30 Jun 2008 12:06 #223091
by wiredgeorge
Can't help you out if you won't answer the questions I put to you. Sorry.
- triggerbilly
30 Jun 2008 12:17 - 30 Jun 2008 12:28 #223097
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
How do i i.d the carbs george ?
they have Keihin on them so i presume they are cv34's
1982 kz750-e3
1983 cb1000c
plano. TX
Last edit: 30 Jun 2008 12:28 by triggerbilly.
- triggerbilly
30 Jun 2008 20:27 - 30 Jun 2008 20:28 #223202
by triggerbilly
Last edit: 30 Jun 2008 20:28 by triggerbilly.
- wiredgeorge
01 Jul 2008 06:48 #223272
by wiredgeorge
Replied by wiredgeorge on topic pilot jet plugged (and stuck)
Would have done as well to figure out why the cylinder wasn't firing... I think you have Keihin CV34 carbs. The advice Limey gave for removing the pilot jets is pretty good... the right slotted screwdriver is critical. With the right screwdriver, I press hard and remove virtually 100 percent of the pilot jets. They have little thread on them so they are not stuck all that bad. If I do strip one, I use an EZ out type tool except I use the tool that is square and drill the proper sized hole. Don't drill too deep or you will just pop the head off.
