Left cylinders lean, Right rich
  • JerseyBomber
  • JerseyBomber's Avatar Topic Author
  • BOO-YAH
25 Jun 2008 18:01
#222173
Ok the bike is a mostly stock kz1000 with pods, 29mm smoothbores and a baffled 4 into 2. Heres my dilemma. At idle and low speed cruising, the left two cylinders will cough out the pods, and the right two cylinders popping ou of the pipes. This is all happening with the air bleed screws 1 and 1/2 turns out and the carbs bench sync'd. If the left two screws are 1/2 a turn out from the seat they are happy. I can bring the right two out to 2 - 2 1/2 turns and the popping is less debilitating but still very consistent. I should mention that the right two cylinders will compress to 120-125 while the left ar at ~140.
Whats going on?
1979 KZ1000 ST Mean, fast, and fugly.
Parting out: \'80 XS400G
PM me!
  • anarki650
  • anarki650's Avatar
Re: Left cylinders lean, Right rich
25 Jun 2008 20:34
#222204
Have you checked the valve clearances? Presumably the jetting is the same in all 4 carbs and the intake is the same in all 4 carbs, exhaust is the same, yadda yadda yadda, which would lead me to believe that fuel/air mixture from the carbs isn't the culprit. And if I'm not mistaken the 1 and 4 cylinders share a coil and the 2 and 3 cylinders share a coil so it probably shouldn't be a firing issue. That really just leaves valve clearances I'm thinking. Of course I could be wrong and someone may know better than me, so feel free to chime in and educate me if you do!!!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • wiredgeorge
  • wiredgeorge's Avatar
26 Jun 2008 06:53
#222282
What type pods are you using?
  • JerseyBomber
  • BOO-YAH
26 Jun 2008 07:57
#222295
I havent been under the valve cover yet to check the clearance, I was hoping to bandaid it till this winter (fresh head on my shelf).
WG, they are old k&n's, washed and re-oiled.
PM me!
  • mtkawboy
  • mtkawboy's Avatar
26 Jun 2008 08:36
#222307
Dido on the valves. How clean are the carbs & what size pilot jets are in it ? Seems pretty far out on the screw adjustment. Pilots may be plugged if its had old gas in it
  • JerseyBomber
  • BOO-YAH
26 Jun 2008 12:13
#222342
The pilots are 25. I think i narrowed it down to the valves out of lash or not getting a good seal: I can have the bleed screws out of the carbs and it makes no difference running. Carbs are as clean as I can get them. Moneys tight otherwise they would be having a day at the spa with wiredgeorge and the other head would be on.
PM me!
  • JerseyBomber
  • BOO-YAH
26 Jun 2008 12:16 - 26 Jun 2008 12:18
#222344
As a side note I found it interesting that if the choke is fully on she runs like a raped ape, if not a little smokey. Is this a sign?
PM me!
Last edit: 26 Jun 2008 12:18 by JerseyBomber.
