will not idle, help needed
  • kz750ohio
  • kz750ohio's Avatar Topic Author
22 Jun 2008 18:30
#221567
I have finished replacing the gaskets on my bike. I have adjusted the shims .127 to .178 is the range on my clearances. The problem I am having is the bike will not idle. It will do fine revving through the rpm's. It will idle with a little bit of throttle but as soon as I let off the throttle the bike slowly drops rpm's and dies. I have tried adjusting the idle but it is either way to high or drops and dies. The float levels seem fine checking with a clear tube. I am not sure what else to check. Any idea's would be appreciated.
cheers,
max
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: will not idle, help needed
22 Jun 2008 18:38
#221569
Easy one... replace the pilot jets and clean the pilot circuit for each carburetor. The jets are Mikuni type BS30/96 and you can buy new ones at www.z1enterprises.com - That will most likely take care of the idling issue. You aren't getting either gas or air in the pilot circuit (or perhaps either!).
