- Thank you received: 1
bench sync...
- BoZ650
- 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
Tony
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
- The Milkman
- Thank you received: 194
- BoZ650
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
Now I found this:
members.dslextreme.com/users/bikecliff/i...carb_sync_notes.html
'85 GPz550(ZX550-A2)
- Bluemeanie
- Thank you received: 14
- Bluemeanie
- OLTIMER
- Back when I was your age, ...
edit: MEH! These pix are the HUGE!!! Diagrams are to the right in the scan image.
this is from a 78 KZ 650 D1 (SR), but itm was the same on the 78 650b I used to own.
Wrong side - notice the large gap:
Correct side - notice the square cutout:
Scan from the manual :
1978 KZ650-D1 SR
Sioux Falls, SD, USA
The shortest distance between two points is under construction.
- wiredgeorge
- Hagphish
\'81 KZ550
\'99 XLS
Whatever puts wind in your face
- keithnra
- steell
Last, put the carbs on your bike and use a manometer to synchronize as they won't be perfect but at least you will be able to open and close the slides sufficiently.
Yeah, no kidding! The CV carbs on my twin were way out just bench synching them, I was surprised how much they were out when I put the manometer on them.
