Best Type Of Gas To Use
  • Thistle
  • Thistle's Avatar Topic Author
20 Jun 2008 18:45
#221229
Can anyone tell me what the best type of gas is to use with my 1980 kz 550c and 1981 kz 650h
i am running both bike on the top gas but was wondering if this is necessary to do so or if i could drop them down to regular?
thanks
KZ550C1 1980
KZ650H1 1981
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Best Type Of Gas To Use
20 Jun 2008 19:24
#221238
Regular gas is what these motors were designed for, unless you've done some major modifications (big bore kit, etc) I used to run premium but found it to be a total waste of money. I used to advance my initial timing ala hot rod style (needed premium then) but have since gone back to stock specs and regular fuel. Bike actually runs better too.
  • bountyhunter
  • bountyhunter's Avatar
20 Jun 2008 21:54
#221273
Use 87 and see how it runs. If it doesn't ping, use it. If it doesn't run right, try 89.
  • Thistle
08 Jul 2008 19:58
#225016
So here's an update to this question.
Switched to regular 89 gas and the bike runs great! Much better than with the 91 or 93. In fact I was experiencing some mild hesitation on the low range and it felt like "pulsing" at an even speed with about 4k on the revs. I was thinking that maybe some little blockage in the recently cleaned carbs was causing this. Changed the gas and wow...... the 'pulsing went away and also the low revs pick up much improved.
Thanks for the tips!
Dave. :)
KZ550C1 1980
KZ650H1 1981
  • slowman
  • slowman's Avatar
09 Jul 2008 03:37
#225090
If the station I'm at is not selling 10% ethanol I get 87.
If the station is selling 10% ethanol I get 89.
Avoid ethanol if you can help it... it'll dry out all the rubber parts of your fuel system.
1979 Kawasaki KZ1000 LTD
The only thing better than the sound of a carburettor opening is the sound of 4 carburettors opening simultaneously!
  • coppertales
  • coppertales's Avatar
09 Jul 2008 09:08
#225146
My KZ110A2 runs better on mid grade in the summer and regular in the winter. My KZ1100D runs better on hitest in the summer and regular in the winter. I just did a ring job on the A2 so that might change as the rings seat. I only have a couple hundred miles on it. It does run better each day. Depends on the bike, I guess.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • Limey
  • Limey's Avatar
  • 3 Years in the U.K. - Brought the KZ with me!
09 Jul 2008 13:05
#225191
Unfortunately, you can no longer avoid ethanol. It used to be only the "cheap" gas brands had ethanol, but our beloved President said that in order to save oil(?), we must all use ethanol! In MI, they used to have a placard on the pump stating it contained ethanol - no longer! There is a simple test to figure it out if you are interested.
I doubt if any of our bikes will be affected by it, they are new enough that the effects of ethanol in fuel were known, and avoided. But if you have any gasoline powered equipment from the '60s or early '70s, be careful. Fuel lines and carb seals are the most likely problems!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
  • Saki Jockey
  • Saki Jockey's Avatar
09 Jul 2008 13:14
#225196
I used to run Sunoco 94 religiously, then ended up with a tank of 87 octane a few summers ago during a major blackout. I haven't used anything but 87 since.
Rob A.
550 A4
GTA,
Ontario, Canada
  • slowman
  • slowman's Avatar
09 Jul 2008 13:39
#225208
Unfortunately most non-ethanol stations in Madison, WI are gone. We are luckier than most of you who have no choice but ethanol or no gas.
For reference, if anyone is in the Madison area... the ONLY non-ethanol station in Madison, WI is now Bennett's Sinclair on the corner of old Highway 12 North and Century Ave. way up in Middleton. There was a Shell that just switched over the other day. Bennett's is the ONLY place I go for gasoline.
My car doesn't like ethanol either. I have an old '84 BMW 3 series and the Motronic 1.0 computer just doesn't know what to make of the 10% corn! :D
  • 76 LTD
  • 76 LTD's Avatar
09 Jul 2008 13:39
#225209
ethanol is a waste of corn that could be used to make good whiskey!if you must use ethanol try putting about 1/4to1/2 cup of marvel mystery oil in the tank(Full Tank) it will help keep the gaskets and o rings in the carbs from drying out.
  • kzwolfsr
  • kzwolfsr's Avatar
09 Jul 2008 22:24
#225280
I do something similar with my fill ups. I use 85 and every once in a while I add gumout injector/carb/ valve cleaner. That stuff has a 3 in one oily residue which is like a lotion to the rings.
Original man of the Caribbean
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
10 Jul 2008 06:02
#225316
For those that don't know, remember this:
Octane is a detonation (and ignition, for that matter) INHIBITOR.
The higher the octane, the LESS likely the fuel is to completely burn, or detonate.
High octane fuel is only required in engines with HIGH(er) compression to avoid detonation.
Some people who have normal engines use the next octane up (89-ish?) when in extreme conditions that might increase the likelihood of detonation (pinging); like extreme heat, etc.
All of our engines, unless modified for performance, should be running on regular ol' regular.
The use of high(er) octane fuels in our regular engines will only cause hesitation and carbon build-up from unburned fuel.
...Okay, I re-checked the above for accuracy, but if anybody catches an error there, let me know....
B)
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
