29 smoothbore- fuel service level?
- twinkyrider
18 Jun 2008 18:11 #220774
by twinkyrider
78 kz1000A
Fond du Lac,WI
29 smoothbore- fuel service level? was created by twinkyrider
I don't what the fuel service level is for 29 smoothbores. I'm attempting to adjust now but the tang on the float has to be bent up quite a bit to get to 3mm from base of carb.
78 kz1000A
Fond du Lac,WI
- twinkyrider
18 Jun 2008 20:22 #220807
by twinkyrider
78 kz1000A
Fond du Lac,WI
Replied by twinkyrider on topic 29 smoothbore- fuel service level?
Never mind... adjusted them to 3mm, polished the needles and seats , took her for a test run... runs like a raped ape now!!!! (74 Z1). The fuel sevice level as we got the bike was 0mm!!!! No wonder it wouldn't get up and go!!!
However if someone DOES know the actual fuel sevice level, let me(us) know. Pat
78 kz1000A
Fond du Lac,WI
- keithnra
19 Jun 2008 03:11 #220851
by keithnra
Replied by keithnra on topic 29 smoothbore- fuel service level?
do u know anyone who has a jet block for a smoothbore carb or maybe an extra carb body, i need one badly. thanks keith
- FastKaw1
19 Jun 2008 06:02 #220864
by FastKaw1
Replied by FastKaw1 on topic 29 smoothbore- fuel service level?
There is a special tool for that. I think you can get one through z1 enterprises.
Same tool for early 73-74 28mm carbs and 29's carbs.
Or if you have a extra float bowl plug you can drill it and install a hose nip.
add clear hose and your good to go
XENU
XENU
- twinkyrider
19 Jun 2008 06:24 #220866
by twinkyrider
78 kz1000A
Fond du Lac,WI
I used a cork and black tape, drilled a small hole through the cork and inserted a 3/16 nylon coupler and clear tubing, worked like a charm.
Sorry no extra parts.
Anyone got a fuel service level?
Thanks, Pat
Thanks, Pat
78 kz1000A
Fond du Lac,WI
- wiredgeorge
19 Jun 2008 07:09 #220868
by wiredgeorge
Replied by wiredgeorge on topic 29 smoothbore- fuel service level?
I don't think Mikuni ever published the service fuel level. I suspect it is 3~4mm.
- twinkyrider
20 Jun 2008 09:54 #221124
by twinkyrider
78 kz1000A
Fond du Lac,WI
FYI 3mm worked for me! Pat
78 kz1000A
Fond du Lac,WI
- barkers41
27 Jul 2009 16:41 #309706
by barkers41
Replied by barkers41 on topic 29 smoothbore- fuel service level?
guys i need help
just finished rebuilding my carbs and im stuck. i dont have a dawn clue about the adjustment level of my floats. thanks, i really appreciate
1982 kz1000
1982 kz1000
- Thank you received: 2098
27 Jul 2009 17:42 #309716
by Patton
Replied by Patton on topic 29 smoothbore- fuel service level?
