Almost there but not quite
  • jdsmithinc
  • jdsmithinc's Avatar Topic Author
  • You want some of this? Huh? Do ya?
16 Jun 2008 14:18
#220367
Ok, the guy that I took the bike to set the needles at the second from the bottom slot. The bike runs a heck of a lot better and only a slight hesitation at about 4500 rpm and clears a little after 5500. If I do not try to be a speed demon and ease it up in rpms it will not hesitate. The guy said I need to get #115 main jets and leave the needles where they were. I had another guy tell me that the needles need to be set at the third slot and run #120 main jets. I am not sure what to do here. Any help from you guys would be appreciated.
74 Kawasaki Z1 900
78 Honda CB 750
97 Ford F-150
Mustangs, too many to list on here (I like to rip the pieces of junk apart)
Located in Shelby, N.C.
If life gives you lemons make lemonade, then find someone whos life was given vodka and have a party.
Re: Almost there but not quite
16 Jun 2008 18:50
#220416
Hello . . . Hello? . . . Tap -- Tap -- Tap!
Is this thing on? :laugh:
  • wiredgeorge
  • wiredgeorge's Avatar
17 Jun 2008 06:45
#220471
If you need help, please clarify what your current jetting set up is and what your airbox/pipes are. You are basically asking for us to comment on two individual's opinions who probably know that info. Are we talking about Z1A carbs?
  • bountyhunter
  • bountyhunter's Avatar
17 Jun 2008 12:32
#220522
Define hesitation: do you mean you have the throttle wide open and you feel a "weak spot" as the engine is revving through the range of 4500 - 5500 RPM? From what I understand, if the mains are too small you will feel the power go down as you are revving wide open up to redline, and it gets worse the higher you rev. If it is only weak in a narrow range and then it hits strong past it, that doesn't sound like mains to me.
  • wiredgeorge
17 Jun 2008 14:02
#220540
bh - Too small a set of mains feels like this: If you have a BS34 assembly on a KZ1100 with stock jets (#122.5 maybe or something like that) with the stock airbox, it will pull redline. Put some good pods on. Take the same bike and it will pull great to 6K rpm and then feel like you are running into a net... just woon't pull in top gear. Put some #130 mains in and when you hit just over 7K rpm where the cams are starting to make their biggest power, again, it is like running into a net... just doesn't want to accelerate past that point. #140s will generally get you to redline cleanly. #150s won't get you to redline any better and #160s will start the bike smoking and it won't feel crisp. I doubt you can pull redline.
  • jdsmithinc
17 Jun 2008 14:40
#220546
Sorry about that, the carbs are from what George told me, from about a 78 KZ1000 with 112.5 mains. I have aftermarket 4 into 1 headers with no baffle and individual pod filters. When I say hesitation I mean it is bogging down, like it is getting no fuel at that range. When I let up on it and ease it up past that point it will go just fine.
74 Kawasaki Z1 900
78 Honda CB 750
97 Ford F-150
  • bountyhunter
17 Jun 2008 14:50 - 17 Jun 2008 14:51
#220547
That's what I fugured, which is why I thought a narrow range of weak pull isn't the mains if it pulls strong past that point.
I was thinking the same, maybe din't say it exactly the same.
Last edit: 17 Jun 2008 14:51 by bountyhunter.
17 Jun 2008 15:19
#220556
Here is some additional background pulled from jdsmithinc's recent topic Z1 900 bogging down at mid rpm range 4k to 5k
jdsmithinc wrote:
...I have the bike timed just right, and have done all the necessary stuff to get it running right. The plugs are still sooty (did the coil rewire already). I was told by a bike shop here in NC (he works on old KZ's) that since the plugs are sooty, I am getting to much fuel and I need to lean up my needles by moving the clip up one notch at a time on them until it is running right. Does this make any sense to you guys? I dont want to tear into it for nothing...
Ok, I decided to go ahead and move the clips up one notch on the needles. I noticed that the #3 carbs clip was set on the very bottom notch, and the rest were on the second from bottom. #3 looked a little scarred up from the PO on the inside of round piece. The needle itself looked a little scarred up at the second slot. Right now I have all four set at the third from the bottom, and it sounds like it is starving for fuel, basically what it was doing at higher rpms when you twisted the throttle pretty good. Am I wasting my time? Should I set them all on the very bottom notch or on the second from bottom?
I dont want to tear into it for nothing -- a legitimate concern here, because even perfect carbs cannot compensate for faults in non-carb components.
This information from wiredgeorge's website says it best -- Click here > wg's site
I have the bike timed just right -- that's good, and would hope that a strobe-type timing light was used to also assure proper operation of the advancer by watching it move back and forth while changing the rpm.
did the coil rewire already -- that's good, and should assure battery voltage is getting to the coil. But is battery voltage adequate (12-13 volts at idle, and 14-16 volts at 3000-4000 rpm, measured across the battery terminals)? But remember, adequate voltage to coil does not assure good quality spark at the plug. What is spark quality at tip of plug -- good fat spark?
Has compression been tested?
Are valve clearances within specs?
Cam chain slack properly adjusted?
Clean and clear air filter (and not blocked by something like a shop rag stored underneath the seat)?
Correct carb float bowl fuel levels verified by the clear plastic tube test?
Usually best to not fool with any carb adjustments or alterations until all the above non-carb components and floatbowl fuel levels are up to snuff.
Then and only then might be some need to address the carbs. Usually the oem needle clip position is correct. It doesn't mysteriously morph into an overly rich position. The clip positions in the present case were obviously incorrect. They should all be the same. And set at oem specs, which I believe is the middle position. Would consider changing the clip position to something different from oem specs as an act of final desperation after knowing without doubt that all other carb internals are perfect, including proper size main jet, fuel level, etc.
Right now I have all four set at the third from the bottom -- if that's the middle clip position and per oem factory specs, would leave them in that middle clip position.
all four set at the third from the bottom, and it sounds like it is starving for fuel, basically what it was doing at higher rpms when you twisted the throttle pretty good -- are plugs still sooty?
Am I wasting my time? Should I set them all on the very bottom notch or on the second from bottom? -- Moving all the jet needle clips back to the factory specified middle position was not a waste of time. Any further carb fiddling before attending to the above mentioned non-carb components is a waste of time.
Am thinking there's nothing here that won't be found in the FSM.
Hoping to be of help, and don't mean to sound preachy.
Good Luck! :)
jdsmithinc wrote:
1. Advancer is working properly
2. Voltage is fine.
3. No way to test compression
4. Dont even want to think about tearing the head off for valves
5. Cam chain slack? How do you adjust this?
6. Filters are brand new.
7. Built a stand for the carbs to set the float levels
8. Plugs still sooty.
9. I think I am just going to sell it, and get one that runs. I think I am in over my head.
10. If there is anyone in my area that may be able to come over and help me out I am all in!! I can pay!
Thanks for the good report.
Checking valve clearances is a routine maintenance item, which does require removal and replacement of the valve cover (not difficult), but does not require tearing the head off. Feeler gauges in the necessary smaller sizes are required.
No way to test compression -- A compression tester is relatively inexpensive, and often available on loan from local auto-supply store such as AutoZone.
Cam chain slack? How do you adjust this? -- This routine maintenance item is quickly and easily performed, and doesn't require removing anything (except possibly the points cover to set crank position at the T mark (TDC) during the adjustment).
in over my head -- anyone unfamiliar with these bikes is similarly situated without an FSM (factory service manual) or good aftermarket manual at hand. Although an on-site search often provides detailed procedures.
If there is anyone in my area that may be able to come over and help me out I am all in!! I can pay -- Getting some local help from a more experienced owner is a good idea. But would pay for an FSM. These often appear on eBay. It's an essential tool.
going to sell it, and get one that runs -- okay, but won't prevent need for attending to routine maintenance (same as when they were brand-new).
Good Luck! :)
Back to the present thread -- to be assured of having pristine as-new perfectly jetted road-tested carbs, send them to wiredgeorge. :cheer:
  • wiredgeorge
18 Jun 2008 06:17 - 18 Jun 2008 06:18
#220666
If you have 78 VM26 carbs, stick some #20 pilot jets in and clip to 4th slot on the jet needle. That should fix your problem. Mix screws should be about 1 3/4 turns out from lightly seated.
Last edit: 18 Jun 2008 06:18 by wiredgeorge.
