Fuel in manifold ports
- 77_650B1
15 Jun 2008 03:47 #220117
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Fuel in manifold ports was created by 77_650B1
Hey guys,
I've been getting fuel in my manifold ports for the longest time now. I used to have overflow problems with my carbs, so I put in new float valves, seems to work, I never get any gas out the overflows anymore. I dont know where this gas is coming from, or even if its normal? I made sure to check that she was running on all cylinders, then shut her off and pulled a plug, gas in there every time. I've got a new pingel petcock in my tank too.
May be a moot point in any case, as my carbs are going off to George in July in any case, I was just wondering if I might have a seperate problem.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- JMKZHI
- Thank you received: 48
15 Jun 2008 12:16 - 04 Dec 2008 06:49 #220172
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 06:49 by JMKZHI.
- 77_650B1
15 Jun 2008 14:45 #220196
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Replied by 77_650B1 on topic Fuel in manifold ports
Ahh, ok, yeah thats what I'm talking about. I had never checked them before, but then i pulled one off one day and it was full of gas.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- The Milkman
- Thank you received: 194
15 Jun 2008 15:42 - 15 Jun 2008 15:45 #220202
by The Milkman
Replied by The Milkman on topic Fuel in manifold ports
They do tend to collect fuel in them because they are on the bottom. You can correct it by taking the carbs off and switching them from side to side so the ports are on the top.
You will be actually, puting the ones from cylinders one and two onto three and four and vice versa so the ports are pointing to the outside to make it easier to do a carb sync.
Last edit: 15 Jun 2008 15:45 by The Milkman.
- wiredgeorge
16 Jun 2008 07:32 #220297
by wiredgeorge
Replied by wiredgeorge on topic Fuel in manifold ports
You had better find gas in the vacuum port caps when you remove them. Gas is supposed to come out of the carburetor and go into the combustion chamber. The vacuum fittings are on the bottom and hence the gas. Just remember to pour the little bit of gas out before putting the caps in your pocket.
- 77_650B1
16 Jun 2008 08:35 #220313
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
:laugh: :laugh:
Ok George, duly noted, haha.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
