Not thrilled with carbs right now
- BeeSting
- Drive it like your tax dollars already paid for it
I can't talk about my girl around my fiance. She can't keep a straight face when I talk about siliconing a hose or greasing a shaft or lubricating anything - and besides that, she's jealous as HELL. (Buying my fiance her own helmet didn't help. Now she things I want a threesome)
So I'm still waist deep in hating carbs right now. My petcock is NOT leaking. I'm starting to get into what my issues are. I isolated the vacuum lines - putting caps on #1 and #4. I swapped sides on the manifold breathers and put breather elements on them.
I noticed that one of my boots (going from the carb to the airbox) was not seated properly. From inside the airbox I began pulling them out/off the carbs. As soon as I pulled out the third one the carbs dropped. The hose clamps on the front boots weren't holding anything. Could that be contributing to my problem at all?
NOT riding is killing me. If I had a wiredgeorge down the street I'd be there. As it stands right now, I can't even ride the bike anywhere and I'm in a real bitchy mood.
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)æš—é—‡ã®å¥³
1980 Honda CX500C - GONE
Christine
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- mtkawboy
- Thank you received: 16
- BeeSting
I don't think the outside cylinders are firing now. This doesn't have anything to do with capping the vacuum ports on those carbs, does it??
BeeSting
Christine
- Wildh2oskier
Good luck and thanks.
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- mtkawboy
- dkmk
- Thank you received: 18
As in #1 and #4 cylinders? Did you check your pipes at the exhaust manifold to see if these are cooler (in relation to #2 and #3)? It's been mentioned that you could try swapping coil wires around. Hook up the wires for #2 and #3 to the outside cylinders, and check the temps again. By all means make sure the carbs are seated in the boots and clamped, but you might be barking up the wrong tree looking for carb issues. Good luck.I don't think the outside cylinders are firing now
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- BeeSting
Am I gettin any closer?
To blow out the carb jets - does that involve complete disassembly?
BeeSting
Christine
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- BeeSting
BeeSting
Christine
- snorules
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
