Air Filter ?? Carb Setup ??
- triggerbilly
13 Jun 2008 16:50 #219874
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Air Filter ?? Carb Setup ?? was created by triggerbilly
Ok
I just put a new air filter on my bike (stock 82 kz750-e3)
and now the bike won't start or idle without me blocking the top of the filter housing with an old t-shirt
which means it's sucking in too much air doesn't it.
any thoughts ????????
the air box case has 1 clear vac hose coming out the bottom
and what looks like another hose hole right next to it with no hose on (is this correct) ??
thanks
thanks
1982 kz750-e3
1983 cb1000c
plano. TX
- bountyhunter
- Thank you received: 337
13 Jun 2008 17:44 #219884
by bountyhunter
Replied by bountyhunter on topic Air Filter ?? Carb Setup ??
triggerbilly wrote:
That one might be supposed to go to the crankcase vent? I doubt the air box is supposed to have any uncapped connectors sticking out.Ok
thanks
- triggerbilly
14 Jun 2008 00:16 #219929
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Replied by triggerbilly on topic Air Filter ?? Carb Setup ??
there is one going to the crank vent
this hole is right at the bottom of where the filter sits
(if you take the lid off the filter you can see daylight through to the floor)
1982 kz750-e3
1983 cb1000c
plano. TX
