Accel Pump Rod Parts
- AndrewT
12 Jun 2008 11:19 #219631
by AndrewT
Accel Pump Rod Parts was created by AndrewT
My bike is missing the nut, spring, and two washers that are found on the pump rod for the carburetor. I've been looking around and can't seem to find the spring. Just wondering if any of you guys have either the spring, or perhaps even all the parts (nut, washer, spring)??
Thanks,
Andrew
Thanks,
Andrew
- wiredgeorge
12 Jun 2008 11:42 #219640
by wiredgeorge
Replied by wiredgeorge on topic Accel Pump Rod Parts
Get a spring, nut and the washers at any hardware. The brass nut used isn't necessary... just use any M3 standard nut and loctite it is place when you get it adjusted.
- AndrewT
12 Jun 2008 11:50 #219643
by AndrewT
Replied by AndrewT on topic Accel Pump Rod Parts
How big does the spring and nut have to be?
