KZ 750 Twin making me go crazy (again)
- Wildh2oskier
faq.ninja250.org/wiki/How_do_I_synchronize_the_carburetors%3F
carb syching.
This took the surging out but now it has became hard to start and the motor dies, blurbles and pops at above 1/4 throttle. It will ease up to 65 mph but it you are not going to make it get there in a hurry (again no more than 1/4 throttle)
I'm not that experienced in these things but my guess is it is running lean. The plugs are brand new and look that way.
I'm sorry my description is random and vague but I don't how else to describe my problems. I'll answer any and all questions and try most anything ya'll suggest at this point.
Thanks in advance.
- bountyhunter
- Thank you received: 337
Stock jets?
- Wildh2oskier
- bountyhunter
I'd check fuel levels next.
I'd also check the manifolds and connectors for vacuum leaks.
- ronjones
- Thank you received: 4
- Wildh2oskier
- KZQ
- Administrator
- Thank you received: 1415
One exception might be that your floats have become flooded but that would make for rich conditions.
I'd Look for a vacuum leak.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- bountyhunter
If the carbs have not been cleaned in a while, they probably do need it. I clean mine about twice a year.
- Wildh2oskier
- wiredgeorge
- Biquetoast
- King Jeremy The Wicked
You need to do the clear tube check for float levels. If the fuel levels are set too low, it will run lean and stumble. I would invest in a factory manual, it covers the float levels and a lot of other things...
Your plugs should NOT look new. That is another sign of leanness. The plugs should be a nice warm tan. ALWAYS check and set the things that *can* be set to specs FIRST! There are very specific settings for floats (and points, and etc), and they should be set *exactly*. After that, you can move on to the subjective tings, like carb balance and pilot adjustment (though even the pilots can be set in a reasonable starting range)...
Here's everything I can offer about manuals, available from my site. Links to buy new, or download the digital (be patient, it takes a while)..
biquetoast.com/manuals.html
Now go get 'em...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
- Wildh2oskier
When I did the big teardown (months ago)I took the boots that connect the carbs to the engine off and cleaned them. When I put them back on I just finger tightend them planning to go back later and tighten them.
Well apparently today is later enough. Its a different bike now. :silly:
