Midrange
  • ronkz1000
  • ronkz1000's Avatar Topic Author
Midrange
06 Feb 2006 13:56
#21946
Have an 78 kz1000 it idles good and sounds good wideopen. The problem I'm haveing is it doesn't sound right crusing, It doesn't have that crisp sound more like a burbble. Has the stock carbs on it 115 main jets 15 pilots. Any suggestions on what to do ?:S
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Midrange
06 Feb 2006 14:00
#21948
You didn't mention WHY it has #115 pilots which are not the stock size. You also didn't mention what altitude you are operating the bike, what intake mods, what exhaust mods, what engine mods, etc. Not sure what "burbling" means... are you sure it isn't backfiring?
  • ronkz1000
Re: Midrange
07 Feb 2006 16:34
#22238
Came with the jets that are in it. I live 60 mi. sw of houston. It ran very good with the jets that are in it before. I have rebuilt the top end. No it isn't back firing. I have replaced the points with an Dyna ing. I've checked timing and have sync the carbs (bought an manometer)I guess burbbling would translate (DON'T SOUND RIGHT)didn't know how to describe it
  • JR
  • JR's Avatar
Re: Midrange
07 Feb 2006 16:43
#22243
Probably a long shot but have you changed brands of gas recently ?
Last year in 5th gear and at 3,000 rpm just tooling down main street the beast sounded not quite right. Burbling is probably a good description. It was just within a narrow rpm range. I went back to buying Sunoco and problem gone.
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods
  • ronkz1000
Re: Midrange
08 Feb 2006 05:38
#22389
You know you might have hit on something. It's been sitting for a little while. I think I'll dump a bottle of octane boost in a see how shes goes:whistle:
  • JR
  • JR's Avatar
Re: Midrange
08 Feb 2006 18:37
#22600
.........or maybe dump everything and just get fresh gas ?
Woodstock ON Canada
198 kz750E1, 4->1, K&N pods.
  • ronkz1000
Re: Midrange
09 Feb 2006 06:38
#22699
Well I suppose that would be the better idea!
  • Tower_Monkey1
  • Tower_Monkey1's Avatar
Re: Midrange
09 Feb 2006 07:40
#22709
Are you saying its giving you the blah blah blah blah sound, not like its backfiring, but like its missing when its firing ? Thats the same thing my bike does at low speed in third gear at about 35mph or so . I would be interested in how you fixed this problem.. Wayne
78 KZ650C2 Dyna ignition and coils,Pod filters,4-1 Kerker,CBR Tail Light,Drilled front dics,Custom front fender,1/4 fairing.
  • ronkz1000
Re: Midrange
03 Mar 2006 15:46
#27933
I installed 125 mains 17.5 piliots. sings like a canary nowB)
  • JR
  • JR's Avatar
Re: Midrange
03 Mar 2006 16:08
#27947
Thanks for letting us know the fix and outcome.
Woodstock ON Canada
1980 kz750E1, 4-.1. K&N pods
  • ronkz1000
Re: Midrange
05 Mar 2006 06:45
#28342
:dry: One more thing I did was put the baffle back in the exchaust. I had took it out sometime back(liked the sound)B). But it cruises better with it in. I have an kirker that is open if I wanna run hard I'll just swap the tail peices.
