82 csr1000 34mm jetting ?
- jcleach
11 Jun 2008 17:41 #219436
by jcleach
82 csr1000 34mm jetting ? was created by jcleach
I picked up a very clean csr1000 and would like to improve performance I am at about 1300 feet Have individual filters, 2 to 1's with no baffles and someone has swapped in points from a z1 900 (I checked the part #). is this bad or is it acceptable. I am on a very tight budget. what jets should this combo run?
- jim_palmore
11 Jun 2008 19:52 #219483
by jim_palmore
ENJOY LIFE,, THIS IS NOT A DRESS REHEARSAL.
1991 KZ1000P FROM COPPER TO CHOPPER. MY BADASS BOBBER
Replied by jim_palmore on topic 82 csr1000 34mm jetting ?
I have been messing with this problem for over a month and have learnd this
1) I should have listened when others said not to take off the airbox..
2) rob at www.Z1enterprizes.com finally got the combo for me (parts are on order):P
I have a 1991 kz1000p with cv34 carbs. I am replacing my pilots with #40 jets and changing the mains to #140.. from all I have heard this SHOULD be the ticket.. thats my 2cents worth..
- jcleach
11 Jun 2008 20:00 #219487
by jcleach
Replied by jcleach on topic 82 csr1000 34mm jetting ?
what exhaust are you running? and do you know if the police cam is similar to the 1000j standard, or the ltd/csr cams.,
- jim_palmore
11 Jun 2008 20:26 - 11 Jun 2008 20:32 #219497
by jim_palmore
I made my own pipes from the collectors back. the 2 come into a 2" pipe with a 4" baffel from j&p cycle.
I don't know about the cams but have been told that the cop bikes have the most high performance cams in the kz1000 line. even with the carbs running like crap this bike runs like a raped ape:woohoo:
Last edit: 11 Jun 2008 20:32 by jim_palmore.
