Popping, high idle, surging all overnight
- PFC FNG
- I've got the sickness!!!
05 Jun 2008 09:51 #218100
by PFC FNG
I know it would not be any fun if it was easy, but does it have to be this much fun?
84 ZX750 GPZ (Waiting for paint)
Eastpoint, Mi
Popping, high idle, surging all overnight was created by PFC FNG
Ok. I have an 84 ZX750 GPZ that I just got hold of. I traded my KZ650 for it a week ago and it ran like a dream the whole time, no problems, started right up, idled fine everything. I walk out to the garage this morning and the carbs have leaked gas out onto the motor. Couldn't tell you how much, but it was enough to run down the sides of the motor. I started it and it was fine, then as I let it warm up the idle went up to 4000RPM (no choke) and started popping. I put it in first and turned it around to get it back up the driveway and the motor was surging. When the revs dropped to around normal idle it sounded and acted fine, but any higher than 3000RPM it would start popping again. Any ideas?
Eastpoint, Mi
- OKC_Kent
- Thank you received: 20
05 Jun 2008 10:40 - 05 Jun 2008 10:42 #218110
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Popping, high idle, surging all overnight
Sounds like an air leak. Check for missing rubber caps that seal the vacuum tubes/ports. I'm not sure if your intake manifolds or carbs have them, on my bike they are on the manifolds.
The gas may have loosened them up and they dropped off. If you can't find yours then buy some vacuum caps at the auto store, I think it's 7/32".
Oklahoma City, OK
Last edit: 05 Jun 2008 10:42 by OKC_Kent.
- PFC FNG
05 Jun 2008 10:49 #218115
by PFC FNG
Eastpoint, Mi
Replied by PFC FNG on topic Popping, high idle, surging all overnight
Thank you. I'm off to try it now. Any ideas as to what caused the leak?
Eastpoint, Mi
- PFC FNG
05 Jun 2008 11:29 - 05 Jun 2008 11:34 #218122
by PFC FNG
Eastpoint, Mi
Ok, I think I found the vacumn points, and there is nothing there, cool. I also discovered the source of the leak, my petcock does not shut off. Can anyone walk me through how a vacumn petcock is supposed to function so I can try to troubleshoot this thing?
Eastpoint, Mi
Last edit: 05 Jun 2008 11:34 by PFC FNG.
- PFC FNG
06 Jun 2008 00:04 #218283
by PFC FNG
Eastpoint, Mi
Replied by PFC FNG on topic Still popping, surging, idling high
Ok, I "fixed" the petcock issue, and put the whole thing back together and surprise! It still pops. I started it on full choke, let it run a minute, put to half choke and the revs dropped from 6000 to 4000. I let it sit another minute, and took the choke off and nothing changed. It still sat at 4000RPM. The bike is behaving like it is on half choke all the time. I looked around the mechanical linkages on the exterior of the carbs and everything looks to be in working order. Anyone care to lend an opinion?
Eastpoint, Mi
