Choke Question 1981 KZ750 LTD
- brox
05 Jun 2008 07:48 #218078
by brox
From Bismarck, ND
1981 KZ750 LTD w/Kerker Header
2006 KTM 200 XCW
Choke Question 1981 KZ750 LTD was created by brox
I hope this isn't a dumb question, but when I use the choke on my bike, it seems like it is working when starting the bike, but doesn't seem to increase the idle speed. When I first start the bike on full choke, it fires up and then runs on a really low idle (about 1200 rpm). Then when I turn off the choke the rpms don't change. Just wondering what might be going on.
From Bismarck, ND
2006 KTM 200 XCW
- cafekz750
05 Jun 2008 11:10 #218119
by cafekz750
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Replied by cafekz750 on topic Choke Question 1981 KZ750 LTD
I have an '81 KZ750 and the same thing happens to me. I think it has to do with the fact that it is an actually choke (cutting off air supply) vs an enricher which adds additional gas to the mixture. I have two other bike with an enricher and the idle increases with the enricher on.
- MekonFear
20 Oct 2008 07:12 #242798
by MekonFear
Replied by MekonFear on topic Choke Question 1981 KZ750 LTD
I've had this problem also, but found that by bending the stop tab a couple of mm gives me choke and some enrichment by raising the throttle butterflies about 1 mm.
This meant I had choke and also about an extra 1200-1500 ( so about 2000-2500 in total) rpm when the choke is fully engaged.
Cheers
Ben UK
Cheers
Ben UK
