Pod Filters, what do with Air Switch Hose
- AndrewT
04 Jun 2008 11:04 #217867
by AndrewT
Pod Filters, what do with Air Switch Hose was created by AndrewT
Probably a silly questions, but I'm looking to delete the stock airbox and put in air pods. The only problem I have is what to do with the hose that goes from the airbox to the air switch. Does that need to have a filter put on or what?
Anyone have a recommendations for good pod filters? I was looking at the K&N system, but its expensive!
Bike is a 79 650 C
Bike is a 79 650 C
- KZ_Nue_B
04 Jun 2008 11:13 #217868
by KZ_Nue_B
Replied by KZ_Nue_B on topic Pod Filters, what do with Air Switch Hose
Yes, any line or hose that was filtered needs to have its own filter if you go with pods.
- Bluemeanie
- Thank you received: 14
05 Jun 2008 05:43 #218046
by Bluemeanie
Replied by Bluemeanie on topic Pod Filters, what do with Air Switch Hose
Personally? .... remove the "smog" system and put it on a shelf in your garage. Run a hose from cover to cover and cap off vacuum fittings. Way cleans up the engine.
K&N's are the best, cost more but will last longer than the bike will!
- saxjonz
- KawboyZ
- Thank you received: 76
05 Jun 2008 09:12 #218094
by saxjonz
79 LTD B3
Replied by saxjonz on topic Pod Filters, what do with Air Switch Hose
Yeah and the crankcase breather you can put an angled hose on instead of a filter so junk doesn't fall in it. That little can looking thing underneath the carbs on the block.
79 LTD B3
- ronjones
- Thank you received: 4
05 Jun 2008 10:43 #218111
by ronjones
Replied by ronjones on topic Pod Filters, what do with Air Switch Hose
