Throttle cable problem
- galaxian
04 Jun 2008 05:53 #217812
by galaxian
1977 KZ1000A1, 1979 KZ650 C3
Throttle cable problem was created by galaxian
I just put my carbs back on to my 79 650c. The problem seems to be improper cable adjustment. When i tighten the cable that actually lowers the slides it locks the entire carb and causes the throttle to just stay open or close very slowly. I need it snap back closed.
any help??
any help??
- mariozappa
- Thank you received: 8
04 Jun 2008 06:45 #217822
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Throttle cable problem
There should be a return spring on the carb to pull it closed.
what do you mean 'it locks the entire carb'?
1977 KZ650C1
- galaxian
04 Jun 2008 09:13 #217849
by galaxian
Replied by galaxian on topic Throttle cable problem
The return spring is there.
The cable that closes the butterfly once the slack is tacken up it forces the carb to stay open as if you are holding the throttle open.
- mariozappa
04 Jun 2008 09:38 #217850
by mariozappa
1977 KZ650C1
The only time I've ever had that problem is with the cable binding up because of it's routing, not becasue of the adjustment.
Are the stock carbs and standard cables?
1977 KZ650C1
- OKC_Kent
- Thank you received: 20
04 Jun 2008 09:46 #217853
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Throttle cable problem
Your carbs have butterflies, not slides? My 750 Shaft has CV carbs with butterflies and I noticed the flaps not closing, turned out to be the shafts were binding a bit.
Oklahoma City, OK
- RonKZ650
- Thank you received: 240
04 Jun 2008 09:57 #217860
by RonKZ650
Replied by RonKZ650 on topic Throttle cable problem
It sounds like the cables are not adjusted to work together. You can completely unhook the "push" cable from the carbs and see if things work normally with only the "pull" cable. If so, chances are your push cable was adjusted too tight, working against the pull.
Taking a perfectly adjusted cable setup, it doesn't take much tightening of the push cable to make the carbs stick. I mentioned in the past how I had this problem after adding low bars and no adjustment would work. I elected to run only the pull cable. Going back to stock bars, running both was no problem.
- wiredgeorge
04 Jun 2008 10:36 #217864
by wiredgeorge
Replied by wiredgeorge on topic Throttle cable problem
Kent, I think his butterfly is a bellcrank... it is the butterfly shaped mechanism where the two cables attach. To hang the bellcrank if the return spring is in place means either a cable is mis-routed, the cables are reversed or the cable isn't sitting cleanly in the groove on the edge of the bellcrank. In rare instances, I have seen so much rust accumulate under the throttle sleeve that the carburetors opening and closing can bind.
- galaxian
05 Jun 2008 05:42 #218045
by galaxian
Well i just decided to unhook both cables and oil them. Once i did that the carbs snapped back cleanly. The lesson for me is even though it was working ok before just oil the cables anyway as a way of ruling them out.
