Carb Id
- schrock_86
03 Jun 2008 19:47 - 03 Jun 2008 19:47 #217758
by schrock_86
Carb Id was created by schrock_86
I started this post in engines, but realized this is a better place for it. I have a 81 kz750 it idles fine and runs hard past 5k. But right around 4500 it just falls on its face like its over fueling or something. Also after decelerating if i dont keep the RPM's up it doesnt want to take off right away, like it has a ton of extra fuel. Im not sure what the carbs are for all I know is that they are Mikuni, and are off a 1000cc bike or rejetted. Th guy I bought it from wasnt sure which one it was. Im just trying to figure out what they are so I can rejet them.
Heres some pics hopefully this helps.
Last edit: 03 Jun 2008 19:47 by schrock_86.
- schrock_86
03 Jun 2008 19:49 - 03 Jun 2008 19:50 #217760
by schrock_86
Replied by schrock_86 on topic Carb Id
sorry my pics arent working out
Last edit: 03 Jun 2008 19:50 by schrock_86.
- schrock_86
03 Jun 2008 19:52 - 03 Jun 2008 19:53 #217763
by schrock_86
Last edit: 03 Jun 2008 19:53 by schrock_86.
- schrock_86
03 Jun 2008 19:55 - 03 Jun 2008 19:58 #217764
by schrock_86
Last edit: 03 Jun 2008 19:58 by schrock_86.
- Thank you received: 2098
03 Jun 2008 19:55 #217765
by Patton
Replied by Patton on topic Carb Id
Only one pic is allowed in each post.
Try again by replying to your own post with the next pic.
Then repeat until you have all the separate pics showing one pic per post in successive posts.
Good Luck!
Good Luck!
- schrock_86
03 Jun 2008 19:59 #217767
by schrock_86
03 Jun 2008 19:59 #217768
by Patton
Your initial post had several of the same pic.
Do it again the same way but with only a single pic.
Then reply to your own post with a new post showing the next pic. And so on. Putting only one pic in each post.
Good Luck!
Good Luck!
- schrock_86
03 Jun 2008 20:00 #217770
by schrock_86
- schrock_86
03 Jun 2008 20:01 #217771
by schrock_86
- wiredgeorge
04 Jun 2008 06:51 #217823
by wiredgeorge
Replied by wiredgeorge on topic Carb Id
The air cut off valves mark this Mikuni BS34 assembly as 1983 or newer as the air cut off valves were first used on SOME assemblies in '83.
- schrock_86
06 Jun 2008 19:52 #218454
by schrock_86
What size needles should I use. It currently has a stock airbox w/ a k&n, 4 into 1 and stock ignition.
- wiredgeorge
07 Jun 2008 08:42 #218524
by wiredgeorge
What size needles? I am not sure what you are talking about. Stock jetting is probably #127.5 main jets and #37.5 pilot jets. I doubt the K&N drop in filter or 4 into 1 changes the flow enough to warrant serious rejetting but you will want to check current jetting and let me know what is in there. There should be metal plugs in the pilot wells as the pilot jets pick up gas via a cross passageway with the main jet well. You will need to pull a plug and unscrew the pilot to see what is on its side. The main jet has a number stamped on it... some cleaning might be necessary to read the number.
