Carburetor headaches
- bubbap
- Ride it like you stole it!
So far she runs strong and sounds good, but it appears that I have some work to do on the carburetors. Heres the rundown- won't run under 2 grand, the timing is close but not perfect, runs way too rich the spark plugs are black but dry, accelerator pump seems to be working well but when you throttle up hard it falls on its face and dies. I'm not sure but I believe its mostly a problem with the idle jet but I am not sure. I have used new rebuild kits not jet kits so everything is still stock settings. I'm using pod filters and 4 into 2 Mac exhaust. Any help here would be greatly appreciated.
Thanks,
1979 KZ650, Mac 4-2 exhaust. Restored after 25 years of sitting. Dyna elec coils, ignition. As old as I am, been in the family since new.
- bountyhunter
- Thank you received: 337
I have been working on a full restoration on a 79 KZ650. She hasn't run since 85, and I just got her all back together.
Thanks,
Pods + headers will never run right with stock jets. Try the stock airbox and see if it improves.
For tuning, first step would be to set all the fuel levels in the bowls. Then synchronize carbs and adjust idle screws.
- bubbap
