How do the needle jets come out of a Mikuni BS34?
- DJ
02 Jun 2008 17:27 #217490
by DJ
How do the needle jets come out of a Mikuni BS34? was created by DJ
Just wondering what the proper procedure is for removing the needle jets out of this carb.
Thanks-
Thanks-
- ronjones
- Thank you received: 4
02 Jun 2008 19:03 #217511
by ronjones
Replied by ronjones on topic How do the needle jets come out of a Mikuni BS34?
Remove diaphram and needle, then unscrew the main jet. If it's not varsolled in, the needle jet will slide out, if not use something soft like a stick or stiff plastic to push it up, from the main jet hole. The main jet is what holds it down. When reinstalling there is a pin, a slot in the needle jet slides onto.
- DJ
03 Jun 2008 11:48 #217666
by DJ
Replied by DJ on topic How do the needle jets come out of a Mikuni BS34?
Okay. It seemed a little tight, just wanted to make sure I understood how it was assembled before trying to take it apart. Thanks for the information.
Daron
ronjones wrote:
Daron
- almarconi
03 Jun 2008 22:06 #217789
by almarconi
1981 KZ550C LTD (SOLD)
1980 GS750L
1982 KZ750N1 Spectre (New Project)
Replied by almarconi on topic How do the needle jets come out of a Mikuni BS34?
Best to soak it with some carb cleaner and then use a piece of dowel and a small hammer to remove it. I just got done cleaning a set on my bike and it is very easy to strip the heads on some of the jets/airscrews. Best to take your time and make sure you have good fitting screwdrivers.
1980 GS750L
- DJ
05 Jun 2008 06:23 #218058
by DJ
Thanks, I got them out.
