Carb Clean After many years
- xstreamcanadian
05 Feb 2006 17:59
My original plan was to soak my 12 years of sitting carbs in solvent(thanks to this site i didnt) and I was told that was a stupid idea. So what is the procedure for a thorough clean, remove top and bottom looks simple, do I need new gaskets when I do that? Also, can anyone reccomend a particular procedure for a good clean while maintaing the setup?
Thanks in advance you guys are great!
- rstnick
Re: Carb Clean After many years
05 Feb 2006 18:46
Go into the Archive section up top and do a search for Carb Cleaning, and check the box "search subject only".
this link:
Archives search
Post edited by: rstnick, at: 2006/02/05 21:47
this link:
Archives search
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- JR
05 Feb 2006 19:07
There's a good article here
www3.sympatico.ca/g.boudreau/CarbCleaning.html
Just keep rubber parts and O rings away from solvents. If take them apart then you will probably lose your current setup and will have to set them up again but dont worry - lots of help is available here. Rebuild kits from Z1 Enterprises or Sirius are a good investment. I would recommend them.
Good luck
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods
Good luck
Woodstock ON Canada
- xstreamcanadian
06 Feb 2006 17:43
great thanks a lot. I am getting the 'new' bike tomorrow and will start to clean it up this week, before the Valentines day thing and my wifes birthday which will both sadly keep me out of my shop..... maybe we could do a valentines day cleaning? kinda hard to sell that one I think!
- ltdluke80
07 Feb 2006 19:56
There is a great carb cleaning solution available from yamaha that is ideal for soaking carb bodies and internal carb parts. The instructions are for a "machine running" cleaning procedure but i find cutting the solution with 50% clean fuel and bathing in a container to work wonders. Do not soak rubber, paper, or any non-metal items.
- ran429
- Master of FREE rides!
07 Feb 2006 21:05
Get a few cans of compressed air (unless you have filtered airlines). Just a thought.
Use these on the jets after soaking them overnight in seafoam/fuel mixture. Also soak the bowls overnight in the mixture as well.
I did this and WOW they came out great!
- gas
11 Feb 2006 18:24
I went with the carb kits and I'm glad that I did. This way I got a jet selection and all the gaskets and rubber O - rings etc. You'll likely find that most if not all of your O rings are brittle and hardened, in other words, crap. Don't be afraid of taking your carbs apart, it's wasn't as bad as I imagined it would be. Get an exploded part drawing of your rack (check out the file section above, community, filebase), and an individual carb exploded view, you won't go wrong. Actually the needles etc. inside your carbs are probably fine and a guy can likely get away with just replacing rubber and gaskets (after a damn good cleaning, or two), if you want to cheap out. Another consideration would be buying stainless allan head bolts as a replacement for those dinky little panhead screws on the carbs. I bought a little jug of varsol and cleaned the hell out of everything using an ice cream pail, then I bought a couple of cans of carb cleaner (dismantle one carb at a time) and soaked/scrubbed everything down. I used a toothbrush and made sure that every orifice revealed daylight. Worked like a charm for me. Don't forget to reset your float height before putting the carb rack back onto the engine.
