Popping in carbs
- JanTaliban
- Z750 LTD Twin -83
02 Jun 2008 04:27 #217319
by JanTaliban
KZ 750 Twin -83
Popping in carbs was created by JanTaliban
Hi!
My KZ 750 twin -83 is popping in the carbs when I take of from idle. Does anybody know what could be wrong?
Sincerley/Jan
Sincerley/Jan
KZ 750 Twin -83
- DJ
03 Jun 2008 11:57 #217668
by DJ
Replied by DJ on topic Popping in carbs
I believe that popping from the carbs indicates that the engine is running lean.
- bountyhunter
- Thank you received: 337
03 Jun 2008 14:54 - 03 Jun 2008 14:56 #217702
by bountyhunter
Replied by bountyhunter on topic Popping in carbs
When my 750 twin was popping when I let off the throttle, it was because the pilots were too lean.
Could also be timing.
BTW: did you install new pipes or change to air pods? That will make the engine run lean.
Last edit: 03 Jun 2008 14:56 by bountyhunter.
- Biquetoast
- King Jeremy The Wicked
03 Jun 2008 19:56 #217766
by Biquetoast
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
Replied by Biquetoast on topic Popping in carbs
I'll second (or third) the notion... LEAN!
:laugh:
How do your plugs look? Can you post a pic?
:laugh:
kz750twins.com
- JanTaliban
- Z750 LTD Twin -83
04 Jun 2008 12:02 #217873
by JanTaliban
KZ 750 Twin -83
Replied by JanTaliban on topic Popping in carbs
Thanks everyone, I think I found the problem. I blowed the pilotjets whit compressed air, and the popping seems to be gone... Something must have been stuck in them.
Sincerley/Jan
Sincerley/Jan
KZ 750 Twin -83
