Prime?
  • PFC FNG
  • PFC FNG's Avatar Topic Author
  • I've got the sickness!!!
Prime?
29 May 2008 12:20
#216612
Thanks in advance.
This morning I ran my bike out of gas, I filled the tank and now it won't start. Friend said put the petcock at prime and try to start it. Nothing. It is getting spark just fine but it does not seem to be getting fuel. If I try long enough, I can smell gas but I don't see it and it doesn't seem any closer to turning over. Any ideas?
I know it would not be any fun if it was easy, but does it have to be this much fun?
84 ZX750 GPZ (Waiting for paint)
Eastpoint, Mi
  • BSKZ650
  • BSKZ650's Avatar
Re: Prime?
29 May 2008 14:07
#216628
since you ran it out of fuel there is a possiblity that you cloged the screens in the tank,
do you have a fuel filter inline?
have you checked to make sure you are getting fuel in the carb bowls
77 ltd1000, current rider
76 kz900, just waiting
  • PFC FNG
Re: Prime?
29 May 2008 14:37
#216632
No inline filter. How do I check the bowls?
Eastpoint, Mi
  • bountyhunter
  • bountyhunter's Avatar
Re: Prime?
29 May 2008 15:28
#216640
There should be drain screws on the bottom of the bowls. Turn the petcock OFF and loosen the screws and drain them into a small plastic or glass cup.
BTW: gas floats on top of water, so the bottom of many gas tanks has some slimy water sludge in it. When you get down to the reserve tap, that is a shorter pipe that draws fuel at a level lower in your tank.... where the crud sometimes resides.
If I was you:
1) Take the tank off.
2) Use the petcock to drain it out into a clean bucket. Pour the clean gas off into another clean bucket, dump the slimy stuff.
3) rinse the gas tank with either clean gas or naptha (mineral spirits) type solvent.
4) Drop the bowls on the carbs and clean themm.
5) Clean the petcock assembly and filter screen.
6) Install some inline filters.
  • PFC FNG
Re: Prime?
29 May 2008 15:54
#216646
Will all of this have to be done before I can get this thing running again? Kinda need my daily driver.
Eastpoint, Mi
  • steell
  • steell's Avatar
Re: Prime?
29 May 2008 18:35
#216661
Well, if you started right after you posted, you should be out riding right now :)
  • bountyhunter
Re: Prime?
29 May 2008 19:22
#216667
You can actually see the answer to that: bike fuel systems work on gravity, and the crap all runs downhill.... just like management.
Anyway, if there's crap in the tank and you don't clear it out, it will just keep going downhill and gunking up the jets in your carbs.
It may be a PITA, but everybody with a bike does it on a semi regular basis.
  • PFC FNG
Re: Prime?
30 May 2008 14:00
#216814
As long as you can fit the tools around everything, can you remove the carb bowls without removing the carb rack?
Eastpoint, Mi
  • RonKZ650
  • RonKZ650's Avatar
Re: Prime?
30 May 2008 14:12
#216816
That would be near impossible. Have you removed the drain bolts from the bottom of the bowls and see if gas is flowing? Running out of gas should not cause everything to plug up. You're sure you did in fact run out of gas?
  • PFC FNG
Re: Prime?
30 May 2008 14:15
#216818
Positive. Open vents and milky white shit came out.
Eastpoint, Mi
  • PFC FNG
Re: Prime?
30 May 2008 18:41
#216859
Ok. Pulled the carbs, cleaned the bowls. Reassembled (properly as near as I can tell). Removed and cleaned petcock. Rinsed tank. Still won't start. I popped the drain plugs on the bowls and the carbs are getting fuel. I have spark. I have air. Any ideas?
Eastpoint, Mi
  • bountyhunter
Re: Prime?
30 May 2008 22:19 - 30 May 2008 22:22
#216897
If you are sure you have spark and fuel, the other main piece to check is cylinder compression.
I'd also clean the spark plugs.
Last edit: 30 May 2008 22:22 by bountyhunter.
