- Thank you received: 1
Which carbs?
- CptEDIV
26 May 2008 17:15 - 26 May 2008 17:17 #216009
by CptEDIV
1979 KZ 650 D2 \"Midnight\" blue.
Which carbs? was created by CptEDIV
How do you know which carbs are on your bike? I have the stock, they are Mikunis. Are they VM 22s? They have the accelerator pump on the second carb going left from right. Have the tall tops not the flat square ones. If that helps at all! Thanks.
Oh 1979 KZ 650 D2 I'm pretty sure. Says SR 650 on the plastic and is blue.
-Ed
-Ed
Last edit: 26 May 2008 17:17 by CptEDIV.
- Sandy
- Fly High,Tony
- Thank you received: 13
26 May 2008 17:33 #216012
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Which carbs?
Pretty sure they're all 24mm carbs on the 650's.
1977 KZ1000 A-1
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
26 May 2008 17:58 #216016
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic Which carbs?
The 78 SR's used VM22's in 79 they went to VM24's.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Thank you received: 2098
26 May 2008 18:31 - 26 May 2008 18:43 #216020
by Patton
Replied by Patton on topic Which carbs?
Point to KZ Information in the green ribbon, click Filebase, select 1979, scroll down to KZ650-D2, download the "Giant Test" (it's a good read), go to last page for a comparison chart showing mucho info.
Last edit: 26 May 2008 18:43 by Patton.
- CptEDIV
26 May 2008 20:35 #216069
by CptEDIV
Replied by CptEDIV on topic Which carbs?
My bike is the blue like the 79, says SR 650 on the side covers, and I believe says SR 650 on the original insurance, which is from 1984 or so... It says 79' on the pipes? And so far all parts I've ordered (1979 D2) have fit EXCEPT: 1 carb air screw? It was nearly twice the size.. Also: it says the SR 650 has dual disc in the front and single in the rear. Mine has a single that looks like it used to be double (Has mounting bolts for another disc) but only has a single, and has a drum for the rear. This was my passed away grandfathers bike, and I tried the VIN at kawasaki.com which didn't come up with anything. What do you guys think?
Thanks,
Thanks,
