Replacing Intake Manifolds
  • NiagaraZ
  • NiagaraZ's Avatar Topic Author
22 May 2008 20:36
#215239
When replacing the rubber intake mainfolds do you put Locktite on the screws or the opposite anti seize compound. The screws were a b****d to get out, couldn't get the impact driver on the inner manifolds. It looked like some king of compund was on the screws, but then again it could have been 30 years of corrosion.
1978 KZ650 D1
78 KZ650 D1
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Replacing Intake Manifolds
22 May 2008 21:24
#215251
Run a tap through the bolt holes to assure that they're clean, then of course use all new hardware to help prevent them from "welding" themselves in there again.
I'd recommend using some anti-seize compound, which is always a good idea when combining two diff metals (steel bolts/screws into magnesium? aluminum? engine).
Torquing the new bolts/screws to factory specs is a good idea as well.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • NiagaraZ
25 May 2008 10:11
#215689
Thanks
78 KZ650 D1
