need advice for removing damaged pilot jet and and pilot screw
- boobs
22 May 2008 17:23 #215197
by boobs
need advice for removing damaged pilot jet and and pilot screw was created by boobs
I am in the process of cleaning my carbs on 81 kz1000j. I separated them and cleaned no.1 carb no problem. Taking apart the second i noticed that who ever last worked on this had totally chewed up the pilot jet and pilot screw i cant even get a grip on either at all with anything. They are both recessed and all i can think of is to either drill em out or try using a small chisel to make a slot for the flathead... or magic. does any one have any advice for this
boobs
boobs
- ronjones
- Thank you received: 4
22 May 2008 19:19 #215216
by ronjones
Replied by ronjones on topic need advice for removing damaged pilot jet and and pilot screw
In my case, the jets were totally buggered and needed replacement,anyway, so I used one of the small sizes of this:
tinyurl.com/64xmm2
stuck it down in the jet hole and screwed them right out
- Beatpoet
22 May 2008 23:58 #215263
by Beatpoet
Replied by Beatpoet on topic need advice for removing damaged pilot jet and and pilot screw
I've done the same with a small torx bit
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
23 May 2008 07:06 #215292
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic need advice for removing damaged pilot jet and and pilot screw
Yep, I've got that Craftsman bit set. They're the dog's bollocks for that kind of thing. Highly recommended, IMO.
No "restorationist" should be without 'em....and reasonably priced too, for such helpful tools.
- boobs
23 May 2008 18:27 #215430
by boobs
Replied by boobs on topic need advice for removing damaged pilot jet and and pilot screw
yes thanks that should do the trick ill be headed to sears tommoroow thanks for the help
