kz750 carb leaking/popping
- jordan
20 May 2008 17:22
My bike has run great for the last 2 years. The only modifications have been a header and pods. I did not do any jetting although i probably should have. Lately I have been constantly swapping the carbs and boots from motor to motor trying to get another bike running. I put them back on my bike again and it seems to sound different. Sounded deeper kinda and didn't rev as fast. Now whenever I leave the gas on prime while bike is off(got rid of vacuum/emmision system) gas pours out of the far left carbeurator. Why is this? The bike also seems to pop much more often and even once and a while when it is idling. The pops are very loud and deep. Can somebody please help me with this problem
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- The Milkman
Re: kz750 carb leaking/popping
20 May 2008 18:00
Did you make any adjustments to them while you were switching them around from bike to bike? Have you checked that your intake boots aren't leaking air? As far as the overflowing carb, try tapping the carb bowl with the handle of a hammer or screw driver to see if the float may be stuck, or with you switching from bike you bike you may have jarred them enough that a piece of dirt came loose from one of the pipes that connects the carbs. Try removing the fuel line startin the bike so the carbs drain out, then reconnect the fuel line and see if the rush of gas cleans the float needle. You could also, shut the fuel off drain that carb by removing the plug screw on that bowl, the close it back up and reopen the fuel tap and that may flush any crap out also.
Good luck
Good luck
- jordan
20 May 2008 18:34
alright new update. I just messed with the exhaust and the loud popping sound is gone. BUT, after i went for a ride i noticed that there was literally gas coming out of cylinder 1 from the exhaust. I could see gas slowly running down the exhaust pipe. This leads me to think that cylinder 1 is severely flooding. This would cause carb for cylinder 1 to leak (btw, gas is leaking out the intake opening where the pod filter is) and gas to come out of cylinder 1 from the exhaust. Also, the spark plug from that cylinder is wetter than the others. Would this be caused by a stuck float?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
20 May 2008 19:10
YESSSSSS!!!!:woohoo: :laugh: :silly: :laugh: :silly: :laugh:
I LOVE U KZR!!!
although this was just a minor simple fix, u guys got me back on the road again within 1 hour of problem. Thank u milkman, and thank u 2 everyone who has assisted me in my many problems/projects
I LOVE U KZR!!!
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
20 May 2008 19:11
Oh Yeah, and incase u were wondering I fixed it just how milkman suggested. I beat the piss out of, i mean tapped the bowl and flushed the gas out. After turning the fuel back on it fired right up and ran great. No more gas leaks from either side and popping is at a minimal
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
20 May 2008 19:37
Would suggest also giving the crankcase oil the sniff test to help determine whether any of the excess fuel made it into the crankcase. If in doubt, would change oil and filter.
Good Luck!
Good Luck!
