- Thank you received: 5
High idle vm26 carbs
- anarki650
Also, I have an electronic ignition from an 81 kz650 installed so it can't be timing (at least I hope not because there's no way to adjust the timing on the stock Kawi set up from 81).
Also, all screw adjustments (air screws on the top sides and pilot screws on the bottom) on the carbs are set at a baseline of 1.5. Adjusting the air screws up top didn't change the idle at all but I didn't do anything with the pilot screws because I couldn't get a screwdriver underneath the carbs and didn't feel like pulling the carbs back off last night as it was getting late.
Any ideas on why it's idling so high?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- anarki650
If it's too much, what should I set them at? Anyone know?
09 Kawasaki ER6n
Omaha NE
- Thank you received: 2098
- cafekz750
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
vm26 carbs...all screw adjustments (air screws on the top sides and pilot screws on the bottom) on the carbs are set at a baseline of 1.5. Adjusting the air screws up top didn't change the idle at all but I didn't do anything with the pilot screws because I couldn't get a screwdriver underneath the carbs....
Am thinking carbs have either pilot air screw on the side OR pilot mixture screw on the bottom, but not both.
For example, here's a carb with pilot mixture screw #30 on the bottom --
[click on image to enlarge]
Are the carbs in question manual slide or CV (constant vacuum) slide carbs?
- anarki650
09 Kawasaki ER6n
Omaha NE
- anarki650
09 Kawasaki ER6n
Omaha NE
