NEWbie question on float height KZ1000 1982
  • hamfast
  • hamfast's Avatar Topic Author
15 May 2008 12:53
#213830
Does anyone know the float height for this bike? Cannot find info anywhere.
Thanks
Henry
  • Skyman
  • Skyman's Avatar
Re: NEWbie question on float height KZ1000 1982
15 May 2008 14:18
#213856
18.6mm, I believe.
West Linn, OR
  • Skyman
  • Skyman's Avatar
15 May 2008 14:19
#213858
You've got BS34 Carbs, right?
West Linn, OR
  • Skyman
  • Skyman's Avatar
15 May 2008 14:24
#213859
Here you go:
West Linn, OR
  • Skyman
  • Skyman's Avatar
15 May 2008 14:25
#213860
Of course, it's always better to measure the fuel service level:
West Linn, OR
  • Ilbikes
  • Ilbikes's Avatar
15 May 2008 16:52
#213882
I recently learned the hard way that my 1976 KZ's composite floats each have different density values - setting float height was not the right way to go. The fuel level is the best.
It does not take a $75 tool. Here is one I made/used before my tool came in and it worked perfectly. I don't regret the tool - I like having the tools for each bike's care and maintenance - it's part of the hobby, but float height settings don't cut it for my KZ - I was over-flowing and sloshing fuel during idle/low speeds on 3 carbs out of 4 - all set to 26mm. None of the composite floats were set the same - each took it's own set to achieve the correct 3-4mm below the joint.
$75 tool on top
$1 home-made tool on the bottom. I took an old drain screw, drilled the hole through the head with a small bit, then took a drill bit the same size as the brass "T" fitting and drilled a hole from the head using the pilot hole when drilled from the other side, cut one barb/nipple off the T, used JB Weld to seal/hold the nipple to the drain screw (brazing or solder would work great here and not require cure time), added a 6mm flat washer to help secure the joint, and attached the scrap hose I picked-up years ago from Lowes.
Regards,
Gordon
  • hamfast
16 May 2008 13:18
#214059
Thanks, the float settings were at 24mm, but the fuel level test is the way to go, anyone know what the factory aircsrew intial setting would be????
Thanks
Henry
  • Skyman
  • Skyman's Avatar
16 May 2008 14:40
#214071
Thanks
Henry
If you've got BS34 carbs, the setting is 1 1/4 turns, according to FSM.
West Linn, OR
