Rejetting info needed
  • rsolano
  • rsolano's Avatar Topic Author
14 May 2008 17:32
#213660
I need some help here. I added a Vance and hines 4 into 1 header and individaul air pods. After that the bike didn't run right cause its starving for gas and I know I have to rejet it. I ordered a jet kit but needs someones input as which jet size to put in to run right. My bike is a 76 KZ900 LTD stock except exhaust and air pods. Thanks for everones help on my previous issues......
1978KZ1000, stock w exception of aftermarket 4 into 1 and air pods
  • bountyhunter
  • bountyhunter's Avatar
Re: Rejetting info needed
14 May 2008 18:45
#213665
Wired george is the expert, maybe he will chime in.
I'll wager you have to go at least +2 on the mains above stock and at least +1 on the pilots.
  • jim_palmore
  • jim_palmore's Avatar
16 May 2008 17:55
#214094
I have a kz1000p and was told to use 140 mains and 42 pilots. I realize your bike is a different size but maybe it will give you an idea of what you need
ENJOY LIFE,, THIS IS NOT A DRESS REHEARSAL.
1991 KZ1000P FROM COPPER TO CHOPPER. MY BADASS BOBBER
  • blyle
  • blyle's Avatar
17 May 2008 19:55
#214247
I just "carefully" drilled out my originals. started out with the first bit that was larger and had to redo them to the next size drill bit. A little bit time consumming but I had no access to new ones up north at the cabin.
  • bountyhunter
18 May 2008 14:48
#214394
Problem is that the drill sizes in the small numbered drills skip jet sizes (if you measure the holes and do the math). Next drill up may be two jet sizes up in some cases.
  • jim_palmore
21 May 2008 22:02
#215031
so did the drilling work??? I'm at the same spot. they don't make replacement parts for my year carb so I have to drill out my pilots..
  • bountyhunter
22 May 2008 15:46 - 22 May 2008 15:51
#215176
I punched my pilots from 40 to 50 and it ran better. I drilled the original main jets and ruined them.
Hmm. I thought the old pilots were available. Check this place, they have a huge stock of jets:
www.psep.biz/store/mikuni_pilot_jet.htm
Last edit: 22 May 2008 15:51 by bountyhunter.
