Carb vent hoses and drain hoses what and where !! ???
- Chopperdaddy
14 May 2008 06:30 #213517
by Chopperdaddy
Into all things fast. . . Drag boats, bikes and cars . .. sucker for 50\'s thru 70\'s style also
Carb vent hoses and drain hoses what and where !! ??? was created by Chopperdaddy
Alright, heres what i have and i need you to tell me what to do with it !!!
I have the fuel lines hooked up, I know the float bowls have drains so i need to get hose and run all them out the bottom as there are no hoses on them but there is also to smaller barbs on i think two of the carbs that im not sure what they are or where that hose connects and then on i think two of the manifold rubbers there is barbs that have two different cruddy looking vaccuum caps, they dont look to leak so should i mess with changing them to pretty it up ???
- JMKZHI
- Thank you received: 48
14 May 2008 06:53 - 04 Dec 2008 06:11 #213524
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 06:11 by JMKZHI.
- Chopperdaddy
14 May 2008 07:10 #213527
by Chopperdaddy
Replied by Chopperdaddy on topic Carb vent hoses and drain hoses what and where !! ???
sorry, i forgot everyone in here doesnt have kz 1000 !!!
1980 ltd stock carbs
- Thank you received: 2098
14 May 2008 10:35 - 14 May 2008 10:37 #213556
by Patton
Replied by Patton on topic Carb vent hoses and drain hoses what and where !! ???
Vacuum Plugs from Z1E
On KZ900LTD, the 2 air vent hoses run from carb back through frame and attach to airbox cover.
[click on image to enlarge]
Good Luck!
Good Luck!
Last edit: 14 May 2008 10:37 by Patton.
14 May 2008 10:41 - 14 May 2008 10:43 #213558
by Patton
Last edit: 14 May 2008 10:43 by Patton.
14 May 2008 10:57 #213567
by Patton
