I have fuel flow from the tank but...
- BLSSeattle
13 May 2008 07:48 #213284
by BLSSeattle
I have fuel flow from the tank but... was created by BLSSeattle
Hi all. My bike (79 KZ1300) sat for over a year. I have fuel flow from the tank but it seems that's as far as it goes. I got it running good for an hour or so but now nothing. I did get it started again, after sitting for a day, and it ran for a minute, weakly, and then the same thing happened- loss of power and then kaput. Any hints? I appreciate the help. -Michael
- Z1109R Fin
- Thank you received: 1
14 May 2008 01:15 #213500
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic I have fuel flow from the tank but...
If you have stock vacuum petcock try it on "Pri". This will bypass the vacuum controlled part and there should be a free flow of gas. Vacuum petcock are nice wgen they work but I changed to a Pingel since it definately works. Jeff @ Z1Enterprises.com has them.
- Qdude
- It is all good.
15 May 2008 15:10 #213868
by Qdude
77 KZ 650 C1.
77 KZ 650 C1.
Replied by Qdude on topic I have fuel flow from the tank but...
AAAAAAHHHHH !
Now fuel blockage problems!!!
Run "Sea-Foam" fuel treatment through it and see how much it helps.
Got it at Schucks for a few bucks.
77 KZ 650 C1.
77 KZ 650 C1.
