- Thank you received: 6
KZ1000 Caburetor
- badrhino
12 May 2008 22:03 #213222
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
KZ1000 Caburetor was created by badrhino
I have a stupid question or questions.
1)I am rebuilding a bike i just bought and there is a couple things wrong with it, first the carbs have the main gas line running to the center of them to the fuel rail. What are the two (2) outer intake holes for? These two were just bare when I bought the bike.
2) The fuel pit cock only has the one hose running from it to the center of the carbs (fuel rail) The others are blocked off, where do they go?
These might be dumb questions but it has been a while since I've messed with older (carb'd) bikes.
Thanks
Thanks
Franken Z!
- donthekawguy
- Thank you received: 8
12 May 2008 23:02 #213235
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic KZ1000 Caburetor
The two other hoses are either overflow or vacuum. I'm sure George will see this post and fill you in more. Do you have three places for lines on your petcock? If so two of them are fuel lines and one is a vacuum port.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
