- Thank you received: 1
carb drain weeping
- squints
12 May 2008 17:25 #213117
by squints
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
carb drain weeping was created by squints
My #2 carb is weeping gas from the drain opening at the bottom float bowl. (drain opening -not sure of the correct terminology). I tightened the drain screw but its still doing it, my buddy said the float might be stuck and the opening also may serve as an overflow drain, is he right?
Upstate NY
- Sandy
- Fly High,Tony
- Thank you received: 13
12 May 2008 17:35 #213119
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic carb drain weeping
Make SURE it isn't the t-fitting(union) that's leaking.
That's the t-fitting in between the 2 carbs(there were 2 of them on my 26mm mikunis).
They had ME fooled for 2 YEARS,before I realized that it WASN'T my bowls leaking(with new gaskets).
I took the carbs off the main holding bracket,and wrapped teflon tape around the t-fittings,and presto!They were dry as a bone until I swapped carbs.(3 seasons later)
1977 KZ1000 A-1
- PLUMMEN
- Thank you received: 104
12 May 2008 18:13 #213140
by PLUMMEN
Replied by PLUMMEN on topic carb drain weeping
if its the drain try tapping bottem of bowl with plastic screwdriver handle.sometimes a little piece of trash gets stuck in needle and seat holding it open and that knocks it loose;)
- Thank you received: 2098
12 May 2008 19:34 #213163
by Patton
Replied by Patton on topic carb drain weeping
PLUMMEN wrote:
Yes -- and sometimes helps to do the tapping with the float drain screw removed and fuel flowing through the carb, so while tapping, the flowing fuel may help flush out any trash between the needle and seat. OR can leave the drain screw in place, and do the tapping while the engine is running.
Good Luck!
Good Luck!
- squints
13 May 2008 18:01 #213403
by squints
Upstate NY
Replied by squints on topic carb drain weeping
tapped and drained...tapped and drained.. i also removed and reinsalled the fuel line to the carbs to count out any other causes. Time will tell
Upstate NY
