81 KZ750 Twin
- gaillarry
11 May 2008 17:29 #212893
by gaillarry
1977 KZ1000
1985 Gpz750
81 KZ750 Twin was created by gaillarry
Just picked up an 81 for $100 in good shape but of course its not running. Anyone direct me to a manual as I'm pulling the carbs for cleaning.
1977 KZ1000
1985 Gpz750
- jorn
- vroooooommmmm
11 May 2008 17:36 #212897
by jorn
______________
1980 KZ750G LTD Twin (basket case)
Replied by jorn on topic 81 KZ750 Twin
i dunno bout a manual, but congrats on the great deal!
______________
- bountyhunter
- Thank you received: 337
11 May 2008 18:45 #212916
by bountyhunter
Replied by bountyhunter on topic 81 KZ750 Twin
Fleabay is the source for old manuals.
- steell
11 May 2008 21:05 - 11 May 2008 21:24 #212966
by steell
Replied by steell on topic 81 KZ750 Twin
According to Kawasaki there were no 81 KZ750 twins manufactured.
I'm not picking on you, it's just that it's important because there are large differences between a 1980 KZ750G and a 1982 KZ750M, and you definitely want to get the right manual.
I'm assuming you looked at the date of manufacture on the sticker mounted to the neck behind the headlight, and it said something like 8/81, right? That would make it an 82 model because like everyone else Kawasaki starts manufacturing the next year model after the middle of the current year.
If the front axle mounts in front of the forks, and it says "CSR" on the sidecovers, it's an 1982. If the axle is mounted on the bottom of the forks, and it says "LTDt" on the sidecovers, then it's a 1980.
Here is a pic of what a 80 750G looks like
And here is a 82 KZ750M that I used to have.
I'll try another post
Last edit: 11 May 2008 21:24 by steell.
- steell
11 May 2008 21:26 #212970
by steell
- gaillarry
12 May 2008 04:13 #212996
by gaillarry
1977 KZ1000
1985 Gpz750
Replied by gaillarry on topic 81 KZ750 Twin
My mistake. I bought two bikes off the guy for $100 each, a 76 Yamaha XS650 Twin and the 81 KZ750 4 cyl with pod filters. Since it has pods I hope its jetted properly. I'll find out when I pull the carbs.
1977 KZ1000
1985 Gpz750
- steell
12 May 2008 07:45 - 12 May 2008 07:46 #213023
by steell
gaillarry wrote:
Grrr, that's deserving of a dope slap :S
750 four manual can be downloaded, look at kz.mbsween.com/ .
I have an 80 KZ750E (four cylinder 750) project also
As for the Yamaha 650 twin, Street Tracker!!
www.omarsdtr.com/streetmain.html
Last edit: 12 May 2008 07:46 by steell.
