Mr. Manometer says I have a vacuum leak? KZ1000A1
  • bmyers
  • bmyers's Avatar Topic Author
09 May 2008 18:54 - 09 May 2008 18:57
#212445
Hi folks! I'm in the process of reviving my ole' 77 KZ1000 from the depths of the garage. I am trying to sync the carbs just to see where I'm with a roll-your-own manometer. I'm using 2 stroke oil and some 3/16 tubing with a 4-part T in the middle. When I run the bike with everything hooked up it tries to pull the fluid out of the meter on the 2 middle lines. If I swap lines 1 and 2, 3 and 4 it tries to pull the fluid out of the 2 outside lines. The symptom follows the #1 and #4 carbs so I think that rules out a leak in the manometer.
Am I right in assuming that my rubber carb intakes on #1 and #4 are leaking? I am getting some pops through the carbs on 1 and 4 once in a while. There are cracks on the #1 and #4 intakes but I RTV'd them as a temporary fix and they didn't go all the way through anyway when I looked at them with the carbs off.
Thanks,
Bill
Last edit: 09 May 2008 18:57 by bmyers.
  • The Milkman
  • The Milkman's Avatar
Re: Mr. Manometer says I have a vacuum leak? KZ1000A1
09 May 2008 20:55
#212481
Spray your intake boots with some wd40 or carb cleaner while it is running to see if the idle changes. If it does there is a leak. If there is no leak then the carbs are out of sync #and need to be adjusted. #1 and 4 are farther open than 2 and 3, causing there to be more vacumm on 2 and 3.
  • twinkyrider
  • twinkyrider's Avatar
10 May 2008 05:31
#212521
Where did you get that 4 part tee? And are all 4 tubings the same length?
78 kz1000A
Fond du Lac,WI
  • bmyers
10 May 2008 08:52
#212544
The tubes are all the same length. I got the T from Autozone. They didn't have a huge selection but they did have one of those so I went with it.
Bill
  • bmyers
10 May 2008 13:43
#212581
Well I shot some carb cleaner at the holders and sure enough the RPM's rocketed up.
Anyone have a spare set of carb holders they'd like to sell?
Thanks,
Bill
10 May 2008 16:05 - 10 May 2008 16:06
#212597
If decide on getting new carb holders, here's a link to brand new set from Z1E. :)
Z1E Carb Holders
Last edit: 10 May 2008 16:06 by Patton.
