"82 GPz750 , o ring on air screws ?
  • mjg15
  • mjg15's Avatar Topic Author
09 May 2008 04:37
#212258
Is there supposed to be air air seal on these adjustment screws ? Curious because idle/small throttle opening is very inconsistent , but runs on all 4 cyls ?
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • JMKZHI
  • JMKZHI's Avatar
Re: .
09 May 2008 05:49 - 04 Dec 2008 06:26
#212266
del
Last edit: 04 Dec 2008 06:26 by JMKZHI.
  • Skyman
  • Skyman's Avatar
Re: "82 GPz750 , o ring on air screws ?
09 May 2008 08:21
#212296
What kind of carbs are you dealing with?
On my BS34 carbs, there ARE o-rings on the screws.
West Linn, OR
Re:
09 May 2008 09:35 - 09 May 2008 09:41
#212329
Per Kawasaki.com, here is the 1982 GPZ750 carb, which does show an o-ring.
[click on image to enlarge]
Item Part Number Part Name Quantity
11009 11009-1241 GASKET,FLOAT CHAMBER 4
11009A 16038-022 "O" RING 4
13169 13169-1482 PLATE 4
14025 14025-1603 COVER,MIXING CHAMBER 4
14043 14043-1010 FILTER,FLOAT VALVE 4
16009 16009-1114 NEEDLE-JET,4BE4 4 US
16009A 16009-1115 NEEDLE-JET,4BE3 (Canada) 4 CN
16012 16012-1010 CAP-STARTER PLUNGER 4
16012A 16012-1011 CAP-STARTER PLUNGER 4
16014 16014-1014 SCREW-PILOT AIR 4
16016 16016-1019 PLUNGER 4
16017 16017-1109 JET-NEEDLE,Y-9 4
16030 16030-1016 VALVE-FLOAT 4
16031 16031-1013 FLOAT 4
16055 16055-010 PLATE,NEEDLE 4
43028 43028-1034 DIAPHRAGM,VALVE 4
92022 16034-001 WASHER MAIN JET 4
92037 16008-014 CIRCLIP 4
92043 16032-008 PIN,FLOAT 4
92055 92055-044 "0" RING 4
92055A 92055-1059 "O" RING,CHECK VALVE 4
92055B 92055-1105 "0" RING 4
92063 92063-1038 MAIN JET,#110R 4
92063A 92063-1041 JET-MAIN,#A107.5R 4 (RACING USE ONLY)
92063B 92063-1042 MAIN JET,#A105R 4 (RACING USE ONLY)
92063C 92063-1109 MAIN JET,A115 4 (RACING USE ONLY)
92063D 92063-1110 JET-MAIN,#A112.5 4 (RACING USE ONLY)
92064 92064-1036 JET-PILOT,#A37.5 4
92066 92066-1051 PLUG,PILOT SCREW 4 US
92066A 92066-1064 SCREW,DRAIN 4
92066B 92066-1087 PLUG,PILOT JET 4
92081 16022-016 SPRING,PILOT SCREW 4
92081A 92081-1363 SPRING,DPHRGM VALVE 4
220 220B0406 SCREW PAN HEAD 4X6 4
220A 214B0516A SCREW-5X16 16
220B 220C0512 SCREW-PAN-CROS,5X12,B 14
410 410F0500 WASHER PLAIN 14
461 461F0500 WASHER SPRING 5MM 14
461A 461K0500 WASHER-SPRING,5MM,BLA 14
Good Luck! :)
Last edit: 09 May 2008 09:41 by Patton.
  • mjg15
Re:
09 May 2008 15:10
#212402
Thanks for the research . I've been thru most of the bike and can't get it to run right . I'll try these next .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • po boy
  • po boy's Avatar
10 May 2008 19:30
#212643
Float levels?
Carb sync?
Air leaking around old rubber boots?
1980 KZ750E1
2002 Hayabusa
  • mjg15
11 May 2008 04:43
#212719
Didn't sync , but did check other things . Also had carbs in ultrasonic tank for a couple hours . I swapped all electrics to known good parts with no change . Compression is good , but I have yet to verify valve lash . Plugs and wires replaced , no change . Next is valve lash and sync'ing . And o-rings .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
