Fuel Level Tool
  • Ilbikes
  • Ilbikes's Avatar Topic Author
Fuel Level Tool
08 May 2008 18:49
#212163
Hi fellas. I need a little help. I'm trying to purchase the clear tube and fitting used to check the fuel level in the carbs on my KZ900. This is a stock bike with the original 26mm carbs, but I have suspected the fuel level is too high since I'm getting a rough idle and I have wet fuel in the syncronizer plugs after just a few seconds at idle.
Can someone give me the part #, please?
Thanks,
Gordon
  • bountyhunter
  • bountyhunter's Avatar
Re: Fuel Level Tool
08 May 2008 19:40
#212175
Never seen anybody actually buy the tool. I just get some clear plastic hose and trim (taper) the end with an X-acto knife so it can be shoved into the hole at the bottom where the draing screw comes out with minimal leakage while I read the level.
Re: Fuel Level Tool
08 May 2008 19:47
#212176
  • Ilbikes
Re: Fuel Level Tool
09 May 2008 04:04
#212255
Yes, that is it - part number please......
Thanks,
Gordon
Re: Fuel Level Tool
09 May 2008 04:17
#212256
Patton wrote:
Click right here on The Real McCoy which is the link to Z1E's listing, and look at the oem number. Believing this is the Kawasaki part number.
Good Luck!
  • Ilbikes
Re: Fuel Level Tool
09 May 2008 04:26
#212257
Thanks - sorry I did not realize the link was provided in your first reply. - I've got one ordered just now.
I do appreciate the help.
Best regards,
Gordon
  • Locozuna
  • Locozuna's Avatar
Re: Fuel Level Tool
09 May 2008 08:00
#212293
$$$$$$$$$$$$$$$ :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :blink: :S :unsure: :ohmy: :ohmy:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Re: Fuel Level Tool
09 May 2008 09:17
#212320
Ilbikes wrote:
Thanks - sorry I did not realize the link was provided in your first reply....
Actually my bad, with an unintentional camouflage, and should have noted it as being a link. :blush:
Good Luck with the bike and fuel level measurements! :)
  • bountyhunter
Re: Fuel Level Tool
09 May 2008 12:38 - 09 May 2008 12:41
#212360
YEEEOOOWWWWWW!!!!!!!
That's how you know it's a Kawasaki tool....:laugh:
In the old days whenever I had to buy something from kawasaki, I would figure the fair price and multiply X3 and that would be close.....
now I multiply X10....
Last edit: 09 May 2008 12:41 by bountyhunter.
  • Locozuna
  • Locozuna's Avatar
Re: Fuel Level Tool
09 May 2008 15:27
#212410
Oh! I didn't realize it was made of Kevlar Impregnated Unobtainium!!! Sure will make me feel CHEAP when I use the 10 cent plastic tube again!!!:woohoo:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • RonKZ650
  • RonKZ650's Avatar
Re: Fuel Level Tool
09 May 2008 20:05
#212458
Really $69 for a tool is not all that bad. That being said though, the fuel level gauge is near worthless unless you make sure the motorcycle is 100% level ect, and I don't want to mount carbs, check, unmount 50 times.
Check float with a ruler, assemble and you're done. The float level is not critical. Yes, you don't want no fuel, or overflowing, but in between is not that critical to get exact +/- a couple MM.
  • Ilbikes
Re: Fuel Level Tool
10 May 2008 05:28
#212520
Guys, actually I love having tools. I also need to get this sorted out. I've set my floats to 26mm and I've still got a sloshing problem at idle. My jetting is good throughout the range, it's just at idle I've got a rough idle and if I pull the syncronizer caps off - I've got raw fuel in them. I think that can only come from fuel sloshing around in the bowls from too high a level.
Back to the tools - I enjoy having the right tool for every bike I own. This is part of the hobby for me.
Thanks again for the input/help -
Regards,
Gordon
