After work - better and worse
  • stallau
  • stallau's Avatar Topic Author
06 May 2008 19:20
#211674
I just put a rebuild kit in the petcock after the common response here was that gas getting into the oil was caused by the petcock letting gas by when the bike was off and working it's way through.
The good part is that it started the best it ever has.:woohoo:
The bad part is that full choke needs to be on and if you try to give it some gas it will drop off unless you back off the gas. If you open it and hold it the engine will die.
The only other problem is the petcock lever is very hard to turn.:dry: Should I just back off the two screws by the lever??
Thanks for the help
