- Thank you received: 5
vm26 intake boots for kz650?
- anarki650
01 May 2008 13:58 #210500
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
vm26 intake boots for kz650? was created by anarki650
I'm putting a set of vm26 non-pumper carbs from a mid/late 70s GS750 onto my 77 kz650 b. My question is this: will the intake boots from the GS mate properly to the head on the 650? Or do I need to try to find some aftermarket (or other kz model maybe?) option to make this work? I've already sent a question to Jeff at Z1, just thought I'd throw it up here as well to see if anyone knew off hand.
Thanks!!
Thanks!!
09 Kawasaki ER6n
Omaha NE
- wiredgeorge
02 May 2008 06:30 #210644
by wiredgeorge
Replied by wiredgeorge on topic vm26 intake boots for kz650?
I suspect that the boots from the GS750 will work if they are generally able to mate up with the Kaw cylinder head but I also think you will have to elongate the mount holes as the bolts that hold the 650 carb holders are probably set closer together. I doubt Jeff will know for sure but he might. I think Suzuki carb holders are only available OEM where Kaw carb holders are available aftermarket and Jeff sells them. The VM26/VM28 carb holders Jeff sells WILL fit your bike with elongation of the mount holes... I use a Dremel with a stone to do this elongation.
- anarki650
02 May 2008 07:06 #210658
by anarki650
09 Kawasaki ER6n
Omaha NE
Replied by anarki650 on topic vm26 intake boots for kz650?
Thanks!!
09 Kawasaki ER6n
Omaha NE
