- Thank you received: 3
Thread size on main jets
- Night_Train01
30 Apr 2008 09:55 #210306
by Night_Train01
Thread size on main jets was created by Night_Train01
I just added new air pods to my 78 Z1R and the mid range is very rough. I am going to rejet this weekend. Can anyone tell me the thread size used for the main jets on Mikuni carbs?
- vach
30 Apr 2008 10:18 #210309
by vach
1979 kz650 B. Chicago, Illinois
Replied by vach on topic Thread size on main jets
just curious.. what do you need the thread size for? you can get jets from Z1.
- Night_Train01
30 Apr 2008 15:20 #210339
by Night_Train01
Replied by Night_Train01 on topic Thread size on main jets
I work for a brass fitting company, we have about 100 different gas orfices and I am sure I will find the same style orfice, I just need to know the thread size. Or I will have to wait until Saturday and pull one out from the carb and measure it.
- vach
30 Apr 2008 17:44 #210364
by vach
your going to make your own jets? wow! let us know how that works.. I don't know the measurements though.
- Night_Train01
30 Apr 2008 17:55 #210366
by Night_Train01
The jets will be easy to make with the proper orifice.
- wiredgeorge
01 May 2008 13:24 #210489
by wiredgeorge
Replied by wiredgeorge on topic Thread size on main jets
Make sure the chamfer on the beveled edge of the opening is at the same angle as Mikuni uses otherwise your home-made jet will end up splatting gas out rather than atomizing it. I have had a load of bad pilot jets with this problem. You could spray carb cleaner through them and they splattered and didn't atomize. I figure this out after not being able to make a bike idle. I had to get back with my supplier regarding this problem. Good luck.
