Replacement Vacuum Petcock
- inline79
28 Apr 2008 23:10 #209961
by inline79
Replacement Vacuum Petcock was created by inline79
My vacuum petcock leaks out the outlet port. I tried:
1. Rebuild with just new seals (had to re-use diaphragm) - leaked a bit less.
2. Used Kawasaki rebuild it - new diaphragm just leaks like there's no petcock (maybe too much wear in the petcock).
So my alternatives were:
A. Use a 1977 manual petcock - hard to find, usually broken anyways.
B. Use a Pingel - didn't want to modify my tank. Expensive.
C. Use a Suzuki vacuum petcock - outlet points the wrong way, they look too wimpy.
or
D. Use a KZ1000 Police petcock. (read about it here somewhere). 51023-1375
I chose D. for about $70US. (MSRP $112CAD!!!)
Photo attached. I haven't installed it yet, but I don't see why it wouldn't work. The design inside is much improved so that even if it starts to wear the o-ring will still seal the port.
or
- JMKZHI
- Thank you received: 48
29 Apr 2008 07:36 - 04 Dec 2008 06:03 #210001
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 06:03 by JMKZHI.
- inline79
29 Apr 2008 08:28 #210016
by inline79
Replied by inline79 on topic Replacement Vacuum Petcock
Sorry, forgot to re-do my signature. KZ650C2.
Can't measure bolt spacing right now, but it's probably 50mm.
I had to guess that the KZ650H petcock was the same as the KZ650C2 - they used the same O-ring and mount bolts. That lead to the KZ1000P. Good price for an OEM part.
- JMKZHI
29 Apr 2008 08:49 - 04 Dec 2008 06:03 #210020
by JMKZHI
del
- RonKZ650
- Thank you received: 240
29 Apr 2008 09:57 #210034
by RonKZ650
Replied by RonKZ650 on topic Replacement Vacuum Petcock
My 77 KZ650 measures around 44mm. It's sure not 50 or 34 I can see that clearly. I hope this petcock works for you. I see everything from the GPZ750 to the Concours to the police model all use the same oring, so apparently bolt spacing differences does not effect the oring, so no way to know what you'll get.
- Qdude
- It is all good.
- Thank you received: 1
29 Apr 2008 10:42 #210045
by Qdude
77 KZ 650 C1.
77 KZ 650 C1.
Replied by Qdude on topic Replacement Vacuum Petcock
I went with C. and yes the tubes did not point the right way, but besides that it has been wonderful. Helped with the slow flow issue I had been having as well.
77 KZ 650 C1.
77 KZ 650 C1.
- inline79
29 Apr 2008 17:55 #210144
by inline79
- rstnick
- Thank you received: 377
30 Apr 2008 06:39 #210263
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Replacement Vacuum Petcock
Thanks Conway!
Another option when the time arrises.
How's the Versys treating you?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- rstnick
30 Apr 2008 06:42 #210265
by rstnick
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Oh by the way, I got those Type R stickers you suggested.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- JMKZHI
30 Apr 2008 06:52 - 04 Dec 2008 06:04 #210266
by JMKZHI
del
Last edit: 04 Dec 2008 06:04 by JMKZHI.
- inline79
15 May 2008 22:51 #213943
by inline79
44mm
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
15 May 2008 23:10 #213946
by Skyman
West Linn, OR
Replied by Skyman on topic Replacement Vacuum Petcock
I too went with C. Had to get a little creative with the hose routing, but once I figured that out, it worked great. And the price was right--less than $40 from Z1E.
West Linn, OR
