- Thank you received: 1
Keihin carb Q.
- Makarth
28 Apr 2008 21:33 #209947
by Makarth
Keihin carb Q. was created by Makarth
Hey guys long time no post. Straight to the point though, i have a set of what looks like VB Carbs off a 1982 CB900 custom that i got for free from a friends backyard (im still kicking myself for not getting the starter before scrapping it) So yea i tore the carbs apart cleaned them, broke any seizing, and polished all the goodies and made sure to keep things tight and smooth. Now for the question, has anyone fit these kinda carbs to a 1977 kz1000 or similar? what do i need to make sure works before planting them on the bike? Im very new to vacuum or air pressure operated carbs so yea any help would be lovely. I can pull up the serial number on them and on a side note i found that on a website they say they are 32mm for cb900c's but it looks bigger (34mm) but then again i've never been good at reading vernier calipers.
Also as a beginning note on the project for fitting them i was thinking about using urethane for a custom manifold but any one think it couldn't handle the engine heat?
P.S. the only info i could find close to this were KZ440 LTD's with what seems like similar carbs. I also have pics to be posted later
- 76 LTD
29 Apr 2008 03:01 #209972
by 76 LTD
Replied by 76 LTD on topic Keihin carb Q.
The spacing between carbs is different.Mikunis are easier to tune and get parts for.
- wiredgeorge
29 Apr 2008 11:36 #210060
by wiredgeorge
Replied by wiredgeorge on topic Keihin carb Q.
Actually, parts avialability for the VB series carbs isn't bad. They won't fit the KZ, like noted, but you can find parts. Honda is pretty good about keeping OEM parts available plus there are carb kits. If you had put the actual VBxxx number in the post, I could have told you what they were from probably.
- Makarth
29 Apr 2008 15:18 #210104
by Makarth
Replied by Makarth on topic Keihin carb Q.
so even with making a custom manifold it's a no go? cause i knew the spacing was wrong i was thinking about making new manifolds out of urethane or something to fit the engine. Im guessing the serial is VB43A since it's etched on the side of the carbs.
- wiredgeorge
30 Apr 2008 07:19 #210275
by wiredgeorge
Those carbs are from a 1980 CB900C Custom. Hey, if you can fabricate a manifold, give it a shot. Sounds interesting... just let us know how things work out!
- Makarth
04 May 2008 10:06 #211082
by Makarth
will do... i'm gonna start up AutoCAD sometime this after noon. I have to deal with being 1800 miles away from the bike though since now i'm in hesperia living out my last couple months of being single.
