79 kz650b leaking gas out of carbs 1 and 3??
  • furby1184
  • furby1184's Avatar Topic Author
28 Apr 2008 14:35
#209840
i have a 1979 kz 650B that leaks gas out of carbs 1 and 3 when gas is on whether the bike is running or not. Also bogs out when i throttle up hard. Please HELP!!
1979 KZ 650B pod filters, 4-1 kerker.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: 79 kz650b leaking gas out of carbs 1 and 3??
28 Apr 2008 16:22
#209870
Are you SURE that it's leaking there,and not at the t-fittings(unions) between each set of carbs?
Those unions are known to leak,and the fuel will drip from the bowls,making you think it IS the bowls that are leaking.
1977 KZ1000 A-1
  • furby1184
28 Apr 2008 16:23
#209871
yeah im sure the gas is pissing out of the overflow tubes on the back of the carb
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
28 Apr 2008 16:58
#209879
1977 KZ1000 A-1
  • Qdude
  • Qdude's Avatar
  • It is all good.
28 Apr 2008 17:33
#209886
Those are Mikunis right? with the overflow fittings on the bottoms.
77 KZ 650 C1.
77 KZ 650 C1.
  • chopaweeza
  • chopaweeza's Avatar
  • Chopper Builders Australia
28 Apr 2008 18:57 - 28 Apr 2008 18:59
#209896
It's a real common fault . Typically it's the float needle . They get alittle worn and don't seat properly . Easy to get and easy to replace. Get the replacement types that have the black rubber tip. As the bowls fill with fuel the float rises and the float needle rises until it blocks the flow of fuel . As the level falls through use the float drops allowing the needle to also drop and that lets fuel into the bowls. Much the same as the float in you toilet cistern works . If it's worn at the tip it doesn't seal the way it should and this allows an overflow of fuel regardless of whether the bike is running or not. A real common fault in most older Jap bikes and one thats easy to repair. Most older Kawasaki dealers still have replacement float needles & seats(depending on model) for most 70's & 80's Zeds .
83\' Z750LTD Twin
Mono Shocked Santee GSXR
Last edit: 28 Apr 2008 18:59 by chopaweeza.
  • Qdude
  • Qdude's Avatar
  • It is all good.
28 Apr 2008 21:54
#209953
Has anyone told you about a product called "Sea-Foam"? It can serve to help clean out deposits of assorted 'crud' from your fuel system.
It is not an instant fix, but it did have a significant positive affect on my bike.
It sounds as if you need to work with your float valves. Maybe it is too late to add the fuel cleaner that might have cleaned the crud out of the valves. But for 4 bucks, it is worth a shot.
77 KZ 650 C1.
77 KZ 650 C1.
  • chopaweeza
28 Apr 2008 22:55
#209960
Never and I do mean Never under any circumstance use a product like Seafoam on a bike . It is the quickest way to dislodge crud from your tank and that crud will block every nook & cranny in your carbies. I repaired a CB750 , a Z650B1 and a GSXR750 last year that had used similar products after they bought it off ebay as a "Wonder carb & tank cleaner". The GSXR & CB carbs required a strip down and an ultra sonic cleaning and a complete rebuild using all new parts(at a cost of $650 for the CB750 and over $800 for the GSXR). The Z650 carbs were that blocked that I ended up binning them and buying a replacement set . That stuff is a bikes worst enemy . You think it's going to take the place of a carb rebuild but it makes the situation way more worse.
83\' Z750LTD Twin
  • furby1184
29 Apr 2008 12:41
#210078
yeah it has the mikuni carbs, i just replaced float needles and still having the same issue...... is it worth the headache or should i send them to wg for rebuild?
  • wiredgeorge
  • wiredgeorge's Avatar
30 Apr 2008 07:23
#210276
Before contacting wg about rebuiding, I suggest you go to our website and view the VM Carb Connections link under wg's Tech Stuff Index. I have a sneaking suspicion that your carbs may not be hooked up correctly.
  • JudgeMental
  • JudgeMental's Avatar
30 Apr 2008 08:55
#210301
I had the same issue with my 1978 KZ650. It may be as easy as tapping the float bowl with a wrench. My floats would stick now and then.
  • Limey
  • Limey's Avatar
  • 3 Years in the U.K. - Brought the KZ with me!
01 May 2008 06:24
#210429
I bought rebuld kits for all four carbs on my '78 650. I didn't think the float valves (or idle jets) needed replacing - but they did. However, on reinstallation I had the same problem with one carb. The "overflow" tube was cracked at the base where it goes through the float bowl! I couldn't find a fix (other than a new carb), so I broke the tube off, cleaned the break area and soldered the tube closed! Works perfectly now - but I need to keep an eye out for a leaky float valve!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
