AAAAARRRGGGHHHH!
- Bicycle Lee
1978 KZ1000 police
- Bluemeanie
- Thank you received: 14
- wiredgeorge
- Sandy
- Fly High,Tony
- Thank you received: 13
Lets start there.
1977 KZ1000 A-1
- bountyhunter
- Thank you received: 337
That's almost always the valves. Make sure the clearances are right. If it's still low, you need to pull the head.ok... so I checked my compression and I think THIS is where the root of my problem lies. Each of the 4 cylinders has between 50-60 psi. Not NEARLY enough.
Could this be due to the engine valves? Will I just need to look into a top-end rebuild?
- bountyhunter
That is unusual, I wonder if your head gasket could be hosed?I picked up a simple compression tester and tested each cylinder. I was puzzled when each cylinder read basically the same, low pressure...
You might want to torque the head to see if the bolts are loose.
- Bicycle Lee
I checked valve clearances and here's what I got by cylinder:
#1. INTAKE- .102mm
Exhaust - .102mm
#2. IN - .102mm
EX - .102mm
#3. IN - .051mm
EX - .102mm
#4. IN - .076mm
EX - .102mm
so these are all within the specs I have seen for my model/year. What now? Head gasket? Piston rings?
If not THESE, then what after that?
1978 KZ1000 police
- bountyhunter
- Thank you received: 2829
- Sandy
- Fly High,Tony
But...make sure you use a torque-wrench to do this,so you know for sure where they were at before tightening them.
Also...get this post moved to where it belongs...just noticed that it's in the "CARB" section.
1977 KZ1000 A-1
- Bicycle Lee
1978 KZ1000 police
- Sandy
- Fly High,Tony
1977 KZ1000 A-1
