Simple question!
- jafilson
25 Apr 2008 10:57 #209027
by jafilson
1981 KZ650H1 MFG 1/81 9966 Miles
Keihin vacuum piston carbs. 4 in 1 exhaust.
Pekin, IL
Simple question! was created by jafilson
How does the fuel tank vent? It seems sealed up to me.
(1981 KZ650 CSR) Just curious?
Pekin, IL
- bountyhunter
- Thank you received: 337
25 Apr 2008 11:30 - 25 Apr 2008 11:33 #209042
by bountyhunter
Replied by bountyhunter on topic Simple question!
jafilson wrote:
There's a small hole in the gasket that seals the cap on top. You won't believe how long it takes to remember that when it gets plugged with crud and you keep running out of gas from the vacuum lock.....:laugh:
Last edit: 25 Apr 2008 11:33 by bountyhunter.
- vach
25 Apr 2008 12:50 #209058
by vach
1979 kz650 B. Chicago, Illinois
Replied by vach on topic Simple question!
how can you tell if your gascap is sealing correctly?
- jafilson
27 Apr 2008 16:25 #209597
by jafilson
Pekin, IL
Replied by jafilson on topic Simple question!
Thanks! I still couldn't see a hole but I'll keep looking!
Pekin, IL
- rdgrnr
27 Apr 2008 17:02 #209602
by rdgrnr
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
Replied by rdgrnr on topic Simple question!
vach wrote:
You should be able to feel the spring pressure when you close the tank. And check your cover gasket for cracks and breaks. I couldn't figure out why I kept smelling gas when I couldn't find a leak anywhere. Turned out the cap gasket was cracked, and gas was evaporating out the cap.:blink:
Kevin,how can you tell if your gascap is sealing correctly?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- bill_wilcox100
- Thank you received: 5
27 Apr 2008 18:11 #209616
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Simple question!
For your 1981 KZ650 CSR the gas tank seal goes for about $5 new.
Z1 Link:
www.z1enterprises.com/detail.aspx?ID=1906
It works fine (don't ask).
Best of success.
Z1 Link:
Best of success.
Upgrades:
Montreal, Canada
