EPA cap removal?
- Mike W.
EPA cap removal?
25 Apr 2008 09:49
I'll be pulling the EPA caps this afternoon to clean out the mixture valves. Is there a preferred (fast) way to do this? I'm guessing drill and easy-out at this point.
Mike
Mike
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
96 XR400
99 Beta Rev 3
- wiredgeorge
Re: EPA cap removal?
26 Apr 2008 08:16
Mike, I am not really sure what you are talking about. Not sure what an EPA cap is or a mixture valve. It would also help a lot if you edited your profile to add your bike year/model and your location.
- JMKZHI
Last edit: 04 Dec 2008 06:05 by JMKZHI.
- Mike W.
26 Apr 2008 12:49
Thanks... I've added it a dozen times but it never sticks.
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
96 XR400
99 Beta Rev 3
- Mike W.
26 Apr 2008 12:50
JMKZHI wrote:
Yup... thanks.
Mike
Just guessing... if yer talkin bout the little caps that cover the air mixture screws on the carbs, then be careful when drilling - the screws are just below. JMK.
Yup... thanks.
Mike
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
96 XR400
99 Beta Rev 3
26 Apr 2008 12:58
Mike W. wrote:
Under the info typed into the signature is a box. Do not check the box because it deletes the signature info. In other words, leave the box un-checked and click on "Submit" instead of X'ing out of the screen.
Am guessing you've already done this correctly a dozen times, but maybe this will assist someone else having a similar problem. Maybe a Mod will come to the rescue.
- Mike W.
27 Apr 2008 19:35
Patton wrote:
Thanks:) I didn't check it... the profile just fades away after a short while.
Mike
Mike W. wrote:Thanks... I've added it a dozen times but it never sticks.
Mike
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
96 XR400
99 Beta Rev 3
- wiredgeorge
28 Apr 2008 07:08
Mike, Looks like the signature took this time! Good job.
